Need to auto program tv
I have an emerson tv, we don't have the original remote and I need to auto program the tv in order to view channels. I am not having any luck in getting a picture, even through a cable hook-up.
  • 275 Answers
SOURCE: can't get any tv reception
How do you expect a picture, without any Signal input? Just get any Rabbit Ears Indoor Antenna. Ore, if u wanna first try out, just push a length of Electrical Wire approximately 3-4 feet long into the Antenna socket at the rear of the TV, and then do Auto search. You will be able to view a few local channels - tho a little grainy. If u are satisfied, good, otherwise, then get an antenna.
Posted on Aug 18, 2006
  • 50 Answers
SOURCE: Need Emerson Remote for color TV with DVD Player
You need the remote codes for your cable remote? (if so who is your provider?)
or you need to buy a remote control for the tv?
Posted on Nov 19, 2007
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Posted on Jan 15, 2008
  • 520 Answers
SOURCE: how to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
Posted on May 13, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
How do I get missing channels to view (all between 36 & 98 get skipped)
Does your vcr still work? I'm having same problem but vcr does not work.
Nov 13, 2011 | Televison & Video
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Looking for a remote for an old Emerson TV
Call 1 800 Remotes or go to www.remotes.com. In the middle of the page type in the model number which in your case would be VT1920. I believe the original remote is not available anymore but you can get a substitute remote for that TV. Also have you considered getting a universal remote? Those work on any TV with any component. Try the first two suggestions and hopefully you will find what you are looking for...
Hope this helps,
Sincerely,
Raelyn
Jan 06, 2009 | Emerson EWF2703 27" TV
Programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
Dec 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
Oct 01, 2008 | Emerson EWF2004 20" TV
"ch set" appearing on screen
Need to get into the menu pages to setup the tuner. Just buy a under $10 universal remote but make sure it has a menu button.
Or - many other products that use remotes often have an option for programing it to work with other equipment.
Dec 30, 2007 | Emerson TS1997 19" TV
AIWA VX-T1420 Setting Channels
No it should not light up. If you can not go into menu and add channels manually or auto program. Then you will have to get a remote to work. You could order original remotecontrols.com.
Sep 23, 2007 | GE 13TVR60 Combo
Televison & Video Logo
483 people viewed this question
Top Televison & Video Experts
