Question about Whirlpool LER4634J Electric Dryer
Dryer not heating
Dryer comes on, blows cold air....not heating up and the timer isn't working so the dryer will stay running........help!
  • Anonymous Mar 20, 2009
    My Dryer timer will count down to just before shut off, then stay at that last click on timer and keeps running & running while never getting hot or really drying whats in there.
    Genius:
  • 1,239 Answers
Hi The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet.
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.thank you
please rate it..............
Posted on Dec 02, 2008
  • Whirlpool Master
  • 19,396 Answers
It it blows cold air it is a faulty element or a faulty thermal fuse, this parts should be tested and eventually replaced.
See There's no heat
5 Suggested Answers
colin324
  • 57 Answers
SOURCE: DRYER RUNS BUT, NO HEAT
They normally have a thermal cut out on the rear, behind a small cover or rubber area. Reset this by pushing it in. You have probably let it get too hot at some point by not keeping the filter cleaned often enough, or the outlet hose getting blocked. If there is not a reset, or it doesn't resolve the problem, it may be a fault with the hetaer element. These are not normally difficult to replace, just normally difficult to get to!
Posted on Jan 22, 2008
barkencoa
  • 3463 Answers
SOURCE: electric dryer only blows cold air......no heat
Your problem is associated with the heater element and or thermostats, you need to access these in order to determine the prob.
You have to lift the top cover and remove the front panel to do this.
Depending on your model of dryer, there are at least 2 ways to get into the dryer
It would take too long to fully explain the different ways to get into the dryer,so try this site which should give you all the info you need.
partselect.com
then click on free repair help then click on dryers, and then on my dryer will not heat up.
I would be grateful if you could let me know if you find the info you wanted from this site.
plz rate my solution.
Thanks.
Posted on Jan 03, 2009
  • 1218 Answers
SOURCE: dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Posted on Mar 02, 2010
jsrock516
  • 5911 Answers
SOURCE: my dryer has no heat
If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of heat related problems: 1. Blown Thermal Cut-Out. 2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers. 3. Bad power cord, causing 1/2 the input voltage to be missing. 4. Blown heating element. Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful. NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Posted on Apr 02, 2010
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
Whorlpool dryer timer
I worked ona wp electric dryer not long ago with a heat problem.
Take a look:
DRYER NO HEAT
Jul 08, 2012 | Whirlpool Dryers
Kenmore front load dryer won't heat and timer broken
The most likely cause is the timer is bad. It turns on and off things as it cyles through and the first step is to get the tub turning before it turns on the heat.
Jun 01, 2012 | Kenmore Dryers
Simpson Dryer only blows cold air
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Washing Machines
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
331 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
