Question about Solid Audio Maniac Series MS2 2-Channel Amplifier Car Audio Amplifier
Dont no wat size fuse for lead
I bought this product second hand.. the sub is a kenwood 12inch 300 watt but the lead from the sub and amp is missing a fuse and i do not no wat size the fuse is.. can you help? cheers
    Problem Solver:
  • 14 Answers
Depends what wireing kit you are useing.if you are useing say a 300watt kit then the fuse in the main power lead is normally a 25amp fuse,and this should be installed a maximum of 12 to 18 inches from the batery. hope this helps.
Posted on Mar 08, 2007
SOURCE:
I have the MRP-M1000 amp. I want to hook up 2 alpine subs to this amp. Which alpine subs would be the best for this amp? Please be specific with ohms and watts.
Your best bet will be to wire 2 subs in parallel to the amp. Each sub should be rated for at least 300 watts rms at 4 ohms. This will give you a total impedance of 2 ohms, and your amp will put out 600 watts rms at that impedance. That way, each sub will receive 300 wats rms. I would not recommend wiring subs in parallel, as you will need two 1 ohm subs at 300 watts rms, which are harder to find and will be more expensive. A parallel circuit is the most efficient way to do it.
Feb 23, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
I Have 2 12inch jl audio subs and 1 800 watt kenwood amp and its just not enough boom, so was thinking about installing another amp (performance teknique ) but not sure how to wire it all up......n e help...
How is it wired now? One amp with individual wire to the two subs in stereo mode? What are your plans? Are you adding a matching amp or just buying a larger one to replace the one you have?
Jul 12, 2009 | Sony XM-SD61X Car Audio Amplifier
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
Sub box inner space measurements in inches
First off I have some questions to ask you? what size are your subs and what is the max power on them and the brand name?
Dec 18, 2007 | Car Audio & Video
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
112 people viewed this question
Top Solid Audio Car Audio & Video Experts
Mike Duncan
Mike Duncan
Dalynn Turner
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Solid Audio Car Audio and Video Expert? Answer questions, earn points and help others
