Question about Epson Stylus CX9400 Photo Printer
Epson cx9400 fax
I have a IMac 10,5. I cannot scan using the cx9400. I reinstalled the driver. No luck. I am using a wireless mouse and keyboard. Any suggestions? I have a Epson Stylus 9400 Fax and the paper jammed, I took all of the paper I could see out. Not it pulls to the right side and get stuck. Please advise.
  • nashmilton Dec 02, 2008
    I do not understand why this is abuse, I typed my original message and your system decided to add that Imac 10.5,
  • Epson Master
  • 1,879 Answers
Follow these steps in an attempt to resolve the issue you are experiencing.
1. Turn off the printer and unplug it.
2. Open the entire cover of the unit. Check for and remove any obstructions (jammed/torn paper, etc). Close the cover.
3. Remove any paper from the paper tray. Check for and remove any obstructions (jammed/torn paper, etc).
If there is paper stuck inside the printer, gently pull the paper out toward the front of the printer.
4. Reload 15-20 sheets of plain/regular paper in the paper tray, loaded to the right-hand side. Make sure none of the paper is torn or creased.
5. Plug the printer in and turn it on.
6. Try to print.
(when i had the same problem before, i tried the manufacturer email support, thought i give you a copy)
refund or replacement, it's always your choice.
Posted on Dec 02, 2008
    Genius:
  • 1,550 Answers
I think carriage holder is damaged . You need to replace it .
Just installed windows 10 and now my scan icon is gone and if i try to scan from the control panel i get Communication Error
When you install Windows 10, it usually finds most of the peripheral devices and installs drivers for them. This includes printers. However, it seems that they do not include the scan software for the all-in-ones. What you should do is either reinstall the printer drivers using the installation media for the device, or go to the Epson website and download the driver package for your machine and OS. If there is no Windows 10 driver package, most Windows 8.1 packages will work. Before you install the driver package, however, go to the Printers section of Windows 10 and delete the existing printer, otherwise yo will wind up with two entries in the section and not know which one is which.
Jan 31, 2016 | Epson WorkForce WF-3540 Wireless...
Printer won't work with new computer
You should visit the Epson site and download the latest drivers for the CX9400 and install
Jan 16, 2013 | EPSON Stylus CX9400Fax Series
I use an iMac 21.5"
delete the epson scan app and reinstall it with the latest drivers from epson.
May 15, 2011 | Macsense Computers & Internet
I need to reinstall my printer, but I lost the CD.
You can go onto the website and download the drivers for your operating system. Follow the link below and select your operating system, download, and install.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90753&infoType=Downloads
Dec 02, 2009 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Fax
From your Win Vista Computer;
1.) Try to uninstall ( epson scan ) in the Control Panel / Programs and Features ones it is removed.,
2.) Download TWAIN Driver and EPSON Scan Utility v3.20A > epson12384.exe
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90753&prodoid=63070382&infoType=Downloads&platform=Windows
3.) Ones it is downloaded and installed to your computer., try to launch epson scan ( if same issue persist )
>> On the Device Manager (Vista) if the Epson Scanner is listed under "Other Devices" -- with a yellow " ! " < right click on it and click on update driver., make sure that the option selected is " Install the software automatically (Recommended) and then press next > ..... you may need to restart your computer after this procedure..
>> Then try to scan again
Note >> if a pop on your computer for ( New hardware Found ) just ignore it / close it., after the scanner driver is installed it will go away.....
Jan 31, 2009 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Jan 14, 2009 | Epson Stylus CX9400 Photo Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
