Question about Quinny Buzz Jogger
I need a new tube for a quinny buzz tyre
Where can i buy parts online?
  • QuinnyHelp Jan 20, 2009
    I am having the same problem and can not find any retailer to help me order the parts I need, nor will Quinny Buzz let me order directly from them.....great stroller, terrible service though.
  • jmarlowe May 11, 2009
    Same problem.  Terrible Customer service when it comes to ordering parts.
I had the same problem after getting a puncture racing around the centre MK. I got a new inner tube from my local Halfords store, it cost about £4.50 and then got some tyre Slime to puncture proof all three tyres! No punctures since!!
Posted on May 13, 2009
  • 355MARCUS May 13, 2009
    Just an additional now I see this is an international site! Im in the UK and Halfords is a car parts bicycle supermarket type place. Any bicycle shop should be able to help, the Speedi wheel is the same size as many childrens bikes!
I have the quinny buzz and have a problem with one of the rear wheels. It appears to have 5 holes in it (around the inner part that attaches to the plastic centre part, they are very small holes and I had...
hi this is a very easy fix have you searched the web for quinny buzz inner tubes? ebat has loads if you are in the uk
or it is a 12 inch bent valve inner tube my advice is when you have repaired these put in tyre slime
this will help any future punctures by repairing them immediatley and you wont even know
very good stuff had it in mine and never had to pump them up good for any inflatable tyres with an
inner tube
Nov 16, 2010 | Quinny Buzz Three Wheel Stroller
Replacement rear wheel of quinny buzz
You can buy tyres off ebay at about £9 each. inner tubes are very cheap on there as well. Check out local bike shop as they might be cheaper.
Jul 26, 2010 | Quinny Buzz Three Wheel Stroller
Nearly every time i use my quinny buzz the tyers hace a puncture. i have replaced each tyres inertube atleast 3 times
Sounds like you're either very unlucky or have a thorn or something similar stuck in the tyre, poking through into the inner tube. I suggest you take out the inner tube and carefully run your fingers around the inside of the tyre to feel for anything that may be causing your problem.
Failing that, you can by a product for road bikes called Panaracer Flataway Tyre liner http://www.wiggle.co.uk/p/cycle/7/Panaracer_Flataway_Tyre_Liner/5300003783/
It can be cut and stuck to the inside of the tyre, preventing anything puncturing the inner tube through the tyre wall. Good Luck
Jun 19, 2010 | Quinny Buzz Jogger
Have just melted the wheel of my quinny buzz with a fan heater. what can i do
Oh dear, I did the same with a Maxi Cosi car seat buckle not long ago! You can buy all the types of new buzz wheels complete with tyres (front 3 wheel unit, front 4 wheel fork unit, front 3 all terrain air inflated unit and rear wheels) direct from Dorel, go to http://www.dorel.co.uk/contact-us/ or Tel: 01842 763281., they are always super helpful and very nice. Or you can buy them from this retailer (which I found to be a good deal cheaper) http://babyequipmentcomplete.com/main_site/main/index.php?pge=check or on ebay which are definitely more expensive for new wheels, but perhaps not for used ones. You can buy replacement tyres and inner tubes if it's the rubber that is melted and I think you can also buy replacement wheel covers from the same places, if it's just the outer plastic that has melted. Hope this helps.
Feb 01, 2010 | Quinny BUZZ 3 Jogger
An you get hard rear wheels for the quinny buzz 3
No sorry but you can get new inner tubes very cheaply off ebay & something called gludge(i think thats what it is called) anyway all bike shops sell it so does ebay, you can buy it to put inside tyre so you won't get a punture or a spray which you put inside inner tube it seals it right away if you get a puncture . it is easy to do I did it myself.
Jan 17, 2010 | Quinny Buzz Jogger
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
No quinny spare parts retailer in the Uk !!!!
Please have a look at these links:
Rear tyre
Rear tube
International shipping available.
These are actually original spares, directly from Quinny, but as the text states, the sizes used on the Quinny Buzz are quite common.
With kind regards,
Babycare.nl
Erwin de Raad
Jun 11, 2009 | Quinny Buzz Jogger
Buzz rear wheels wont inflate anymore
I just ordered new tyres and inner tubes from my local pram shop. 8.50 for tyres each and 5.50 for inner tubes. Pram centre in Glasgow. Also ordered a new front wheel for 29.
Mar 11, 2009 | Quinny Buzz Three Wheel Stroller
How do you change the inner tubes on the quinny buzz
I took the whole tyre off the alloy bit, then when I had fixed the inner tube pushed it back inside the tyre then put the silver alloy bit back on.
Oct 20, 2008 | Quinny Buzz Jogger
Quinny Buzz Jogger Logo
445 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Al Toledo
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
