Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
SOURCE: Replacement blade position.
The blades have such a close tolerance tip to tip on a V belt deck that it makes no difference where they are positioned, On a 3 blade deck the center spindle is forward of the two outer spindles. So for that reason you still get a quality cut. Most all commercial units use a V belt and have a good quality cut.
Some john deere mowers have a timing belt with cogs like a car and their blades have to be in time
90 degrees perpindicular to each other and locked down and if you strike something then the timing will be off and your back working on your mower instead of cutting grass,and the belts are twice as expensive than a v belt.
SOURCE: antique toro riding mower need parts for
Jacks Small Engines. in Maryland
www.jackssmallengines.com/toto_parts_index
or www.WiseSales.com
That is where I got the parts for my 17 year old Toro riding mower
SOURCE: have a toro 217d 1986 model with a 30562 62inch
THIS IS THE WEBSITE FOR THE MANUAL. SO FAR THIS IS THE ONLY SITE I HAVE FOUND WITH THE INFORMATION.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#manualsResultPage
I HOPE THIS HELPS IF NOT PLEASE LET ME KNOW AND I WILL FIND SOMETHING BETTER.
