I had removed the fan from my desktop to clean them
Now when they kick on they are alot louder then they ever was before can you please tell me what you think i can do to sovle this problem. thank you
    Problem Solver:
  • 8 Answers
Well you must have damaged one of the propellors and now it is coming into contact with the fan enclosure i reccomend buying new fans for the sake of 10 pounds get a few new fans instead of playing with faulty ones.
The last thing you want is a PC with no cooling
Good luck
Carl
Posted on Dec 02, 2008
Emachines e4026 non-responsive
I don't think it's an overheating CPU. It would stay on for a bit longer if it was that. My best guess is a power supply issue. Either your power supply is bad, or more likely something is pulling too much power from it. Emachines are notorious for using the bare minimum hardware... possibly the extra hard drive is pulling more juice than the power supply can handle, so it shuts down. Try disconnecting power to the new hard drive and see if the machine comes up. If it does, you need a new, higher wattage power supply.
Sep 06, 2007 | E-Machines eMachines Desktop PC
Why does my pc's power light indicator keeps blinking red (2 beeps) after it powers on and begins to boot, running for about a minute or two?
Hi
This means your PC is doing a Thermal Shut down, the CPU is getting to hot, this means the fan is not running at all or fast enough, or is dusty causing loss of cooling to the CPU.
To fix this open the case look at the fan if its running as it gets louder I would say in your case it is, you need to remove all the dust from the fan and the heatsink I use a small USB fan from poundland (UK) this should stop this error.
Cliff
Aug 22, 2014 | HP Compaq DC7900 PC Desktop
Dell Studio xps 8100: Motherboard changed, when booting up I get to the f2/f12 screen with have a progress bar and computer turns off?
So picture guy, LOL
Most all boards have two power plugs from PSU, (power supply unit)
a 20 or 24pin and a 4 or 8pin.
The rest from PSU are for hardware, except if you have any video cards in pci-e slots, but they are not truly part of the motherboard they are addon.
Then from the case you have power button, reset, pled,hdled.
Sata ports on mobo, cpu fan, addon fans, DVD rom.
Front panel audio.
So now you have taken one memory stick and entered the BIOS, then tried each one.
You need to check each stick.
Now you put in your hdd erase disk, boot from it and you're going to erase your hdd so it's all clean for a fresh install.
Now you throw in the windows disk and you boot from it to install windows.
Right !!!
Apr 16, 2013 | Dell Studio Xps 8100 Desktop Computer...
When the Pc is on the (cooling)fan kicks on and
Yes you do have a problem with your cooling fan. My advice is that you buy a new one get it installed. I can say this to you because I already encounter this kind of problem and this could happen to most old fans. But before buying a new one, please try this..,remove the cooling fan and then clean it with a air blower or simply you brush it to get rid of the dust and then check the wire if there is cut and then install it again and see if that works. Hope this could help you..
Oct 24, 2009 | Computers & Internet
Lifebook N3010 turns itself off after about 5-10 minutes. Do you think it could be the cpu fan? Any quick fixes?
thermal shutdown. more robust electrical insides (19volt/6.3amp draw; more than most for sure!),
so you get way more heat, bigger louder harder working fan, etc....a bit too much, and selfsafety circuit kicks everything off. it uses a desktop cpu, so that's more heat that otherwise a desktop could handle.
Jul 09, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
Tower fan runs fast without stopping
either your computer is running too hot (clean it out physically, or clean out viruses) OR the fan is failing, and it sounds louder and faster cause the bad fan bearings are making that noise.
Mar 12, 2009 | Computers & Internet
Dell 3000 PC is extremely loud like a vacumn cleaner right next to your ear... and gets louder and louder throughout the day. Have ran disk clean, Registry Mechanic, and Disk Defrag. Lots of room left on...
Check your cpu fan, chassis fan, and the fan on the power supply. If all the fans are working then the bearings in the hard drive is about to go out. That is if you are not using a cd or dvd rom.
Mar 05, 2009 | Dell Dimension 3000 PC Desktop
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Side by Side Frigidaire Galleria Freezer is making buzzing sound, on and off every few minutes. Freezer is not working, water coming out of ice maker. I removed toe kick plate and removed alot of *** hair,...
clean the heck out of the coils underneath and give the manufacture a call, you should be covered by a 5 yr warr on your compressor(reason i say clean it is if they come see it clogged they'll blame you and deny your warr.stating cust abuse
Mar 10, 2008 | Refrigerators
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
