Samsung dvd-r122 will not play or record dvd's - says can not read or write to disc?
  • 92 Answers
Hi most of the time a cleaning disk or canned air is not enough but you can tray it, you have to open your dvd player and clean you laser lens whit a cotton swabs and alcohol do not use peroxide. Do it slowly and be careful
bye and good chance.
Posted on Dec 03, 2008
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Samsung DVD recorder will play but not record blank discs
Had mine into the repair shop. Junk it, processor is toast. Not worth the money to fix. The guy said he wouldn't even touch it.
Jan 19, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Samsung DVD recorder R122 spits out discs randomly
Go to Samsung .com aand ask for tech help its free
Jun 12, 2008 | Samsung DVDR120 DVD Recorder
Does the DVD-R155 create PC compatible DVDs?
just try to load the dvd disc.and see if it is reading..
Feb 04, 2008 | Samsung DVD-R155
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
DVD recoder not recording
I had this problem with my R120, it first wouldn't record and eventually wouldn't play, just gave either an error message or "wrong disc.' Then, another DVD player I own did the same thing.
What worked? I opened them both up and swabbed the laser lens with alcohol and then the clean end of the cotton swab. Now both work like a charm. I figure that all the dirty rental DVDs lowly drop dust and gunk and over a few months the build-up caused failure.
Just to be safe, I also used canned air to remove from inside the unit, around the circuit board and on the lens.
I'd advise leaving the unit unplugged for a day or more to let any stored energy drain and if you're not familiar with safety procedures, take it to someone who is.
Nov 03, 2006 | Samsung DVDR120 DVD Recorder
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
