Question about GE GSH22JFT Side by Side Refrigerator
Ice dispensor only dispensing crushed ice - not cubed
I have a GE GSH22JFTA, everything works fine (light,water,etc) but the ice dispensor only dispenses crushed ice. I've tried defrosting everything, emptied and cleaned the ice bin, but nothing seems to work.
Each button (cubed/crushed) emits crushed ice only.
Any ideas?
  • 3 Answers
The spring coming off the rod will also cause this problem, also the bypass flap may be stuck open, always check the simple things first, hope this helps.
Posted on Apr 16, 2009
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Posted on Apr 11, 2009
  • Masterpez Nov 07, 2011
    Wow, thanks so much. I was searching for an answer to the same question and your mentioning the rod was right on target. The little lever had come off the little ridge it sits in and I am now getting cubed ice. Thanks soooo much.
I have a GE GSH22JFTA WW that will not dispense water. Does dispense ice, crushed and cube. Panel is not locked. What part do I need? Thanks!
in the back of the fridge there is a module with the solonoid on it to open and close for the water, and it usually get damaged because of hard water, it is about 15.00
Aug 29, 2014 | Refrigerators
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSH25KGMD Crushed Ice Only
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58
http://www.apdepot.com/Buy/IPLFrame.asp?Brand=GE&ModelNo=GSH25KGMDWW&IMGFile=LD1IEWSN&IMGID=uZmA
Aug 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Door ice dispensor will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispensor
It longer pushes in? It doesn't listen to you? It might be the switch. These units pass the water line through the door. Is it jammed or open? Turn off the water, disconnect the line at the base of the door hinge and then turn the water on...with an assistant to catch the water. If there is flow from that point, you have a hint as to where to go next.
Nov 26, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFT Side by Side Refrigerator Logo
686 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
