Question about Olympus Stylus 720 SW Digital Camera
Trouble when Zooming
When camera is on, when I try to zoom in on an object to take a picture, as soon as touch the zoom in button the camera shuts off and I have to turn in back on. Doesnt happen when I press the zoom out button, only the zoom in button. Any ideas??
  • 114 Answers
Well did the camera got wet???, if soo it needs the mainboard to be replaced, if not could just be the mainboard also, but if it´s the second one the repair centre will fix it for free if ?t´s under warranty
Posted on Feb 28, 2007
SOURCE:
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
While taking pictures at normal settings (without zooming), every image is coming blur ,but when we zoom.....then the image is clear. Please suggest how can we correct this setting ?
Maybe you should check the object distance setting in your camera (in FOCUS setting I think). If the camera have this setting, you can choose longer object distance for daily capturing.
Hope this help. (^_^)
Jan 08, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto focus.show the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
How can i change the size of image on the lcd screen
Press the Zoom-in button (the one with the magnifiying glass) to zoom in. Press the Zoom-out button (the one with what looks like a part of a checkerboard) to zoom out.
Zooming in lets you look at a portion of an image, zooming out reverses it.
Zooming out also lets you look at thumbnails and navigate around them to select the picture you want. Then you can zoom in to fill the screen with that picture.
If you're looking at a picture full-screen, you can also press up/down on the multiselector to change your view of the picture.
Feb 14, 2010 | Nikon D70s Digital Camera
Nikon Coolpix 5700 Over-exposure of image whilst zooming in brigh
I now have the exact same issue. When not zoomed or fully zoomed the exposure is correct, however when partially zoomed the aperture does not engage and stays fully open. So basically I cannot really use the zoom or the picture is over exposed. Note - actually about 2/3 mechanical zoom and on works, so I can use a bit of the zoom.
Suggestions?
Sep 20, 2009 | Nikon Coolpix 5700 Digital Camera
I have problems focusing my f8000sd fuji camera when zooming in on small things.IIf I try to zoom right in on a butterfly for example,it will not focus and I can't use macro and get closer in case it flies...
Use spot metering & focus when taking pictures of an object.
Set your camera to highest Megapixel setting, Only use max. optical zoom on the subject (do not use digital zoom) .U dont need to get close to object as you can edit/zoom/crop the picture using any photo software program afterwards .
Aug 09, 2009 | Fuji Finepix Z20fd Digital Camera
Color Bar & Zoom
i think when it zooming slowly by itself the problem comes from a faulty TOP OP C.B.A.
strange but true!
Jul 20, 2008 | Panasonic AG-HVX200 Mini DV Digital...
Can't take pictures.
try zooming in on a object and see it it get clearer. the problem is your zoom lens motor is stuck or malfunctioning. This is a very common problem with digital cameras. sometimes you can take compressed air and blow around the lens and clear the blockage or lightly tap the camera lens down with it off to free up the focus gear. if it does now work it then needs tobe serviced or repaired. I had the same model last week for the same problem. That lens had tobe replaced. but try that first and see if it helps.
Apr 04, 2008 | Olympus FE-190 Digital Camera
Not Zooming
The lens assembly on the Camedia and many other cameras has a special motor to facilitate the zooming. It sounds as if your motor is actually working but it's not engaging the gears to drive the zoom in and out. It could be a fractured gear somewhere in that drive system. I wouldn't recommend pulling one apart. They are a mongrel to put back together the right way. Keep your eyes open on Ebay for your model with a busted LCD or fault not associated with the lens and do a complete lens assembly transplant. Something which is relatively easy to do as long as you take notes of where all the parts and screws go. If you get left with no more than 2 screws when you've finished, you've done well.
Jul 05, 2006 | Olympus Camedia C-770 Digital Camera
Olympus Stylus 720 SW Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
