I have a zebra P330i when I go to print a card the card just goes right through the printer and I get a message that says mechanical error, I've cleaned the printer and theres nothing jamed in it.
  • Anonymous Dec 15, 2008
  • xxl3ww Mar 03, 2009
    I have the same problem, but the card gets stuck right before the print
    head. I haven't cleaned my printer because it's not a problem with the
    printer hardware. Recently, the print server and LCD went out on my
    330i so I sent it in for repairs. I got the hot swap and it worked
    great. When I received my old printer back, I tried to switch the
    printers out.
    The printer (my original) would print a Test card
    from the Zebra Tools under Device Settings, but when it tries to print
    a normal Test card for Windows, it will not print the card. This is on
    Windows 2003 Server, btw. I hooked the loaner back and it worked fine.
    I called Zebra and they told me the server needs to be rebooted. I
    waited until that night and uninstalled the software and
    driver/rebooted, then reinstalled the driver. That did not work.
    Printer still acted the same way. So I decided to hook the loander back
    up.
    Also, I installed the printer on a Windows XP machine to see if it was a driver issue, and the printer works fine on XP
My solution was the cleaning roller. Zebra said the roller was not getting enough pressure to pull the card through. I pressed the metal clips down to give more tension and the printer works great now.
Posted on Mar 11, 2009
I took the print head off and re-seeded everything, put it all back together and it prints now. I just have to adjust the color a bit.
Posted on Dec 03, 2008
Just had machine serviced (reset sensors, recalibrated ribbon, belts checked and orings) I've printed about 20 cards, now I keep getting a "out of cards" message or mechanical error . Thanks
Mechanical error is a message that comes up for many reasons, probably in this case it is because the rollers are turning and a card is not getting to the appropriate sensor on time. Out of cards is shown when the sensor in the feed hopper thinks there are no cards present. Try blowing any dust off the sensors. Perhaps the connection has come loose when the printer was in transit. It could have been knocked if the service agent removed all of the covers to service it.
www.pci-solutiuons.co.uk
Nov 04, 2010 | Zebra P330i Thermal Card Printer
Zebra P330i out of ribbon error message but there is still plenty of ribbon
Send a command "!SA" The printes go recalibrate it self, don't forguet to put a card on the feeder.
Oct 26, 2010 | Zebra P330i Thermal Card Printer
I have an error message " mechanical error" what's the problem?
Can be the sensors from the ribbon are not calibrate, Please sen the command "!SA" from the driver. If still do it, send to someone to have a look.
Sep 20, 2010 | Zebra P330i Thermal Card Printer
I can't manage to print Black PVC cards, in my Zebrea P330i... Error message: "Out of Cards"
There's a small laser inside the printer -- it reflects light, and measures the strength of the reflection. The BLACK is absorbing all of the laser-energy, resulting in the same measurement as if *NO* cards were loaded into the tray. Try GREY PVC cards.
Nov 18, 2009 | Zebra P330i Thermal Card Printer
Keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Oct 15, 2009 | Zebra Eltron P330i Card Printer
Clean prinnter massage
The Zebra printer displays the Clean Printer message when the printer prints a 1000 cards.
This is to maintain printer and ensure good print quality.
The way to clear the message is to get cleaning cards and run a cleaning routine.
The CD that comes with the printer will run a video showing how to run the cleaning cards through the printer. Printer needs 2 unique cleaning cards (1 short & 1 Long)
Feb 01, 2009 | Zebra P330i Thermal Card Printer
MECHANICAL ERROR
Did you check if any card is stuck inside. Run a cleaning card. For that you need to press the button for 3 secs and it will start the cleaning cycle. Feed the cleaning card in the feeder and later from output.
Oct 31, 2008 | Zebra P330i Thermal Card Printer
ZEBRA P33Oi "WAIT TEMPERATURE"
Have you cleaned the printhead yet? If it is easy to get to. Use some alcohol and cotton cloth.
Aug 09, 2007 | Zebra Eltron P330i Card Printer
770 people viewed this question
k24674
jasbo
jasbo
