I have an older Carrier Gas Furnace. I can't read the complete Model number. But since Thursday morning, the blower just keeps blowing cold air, the spark igniter won't spark and the air damper will not open. I replaced the spark igniter and the pilot assembly for $215 and the thing still just won't light. As soon as you turn on the power the blower comes on and just runs. I check my 24v supplies from the transformer, and I am getting voltage. What else could it be. There are no LED's on the PCB.
  • 34 Answers
Nothing will happen until the draft motor come on or the vent damper opens.  if that's happening, are you getting gas?
Posted on Dec 02, 2008
Carrier model fa4anf036 blows cold air periodically and doesn't keep the house warm. Eventually starts blowing warm air then cold again
this model number you gave is for an electric furnace , most often its found in mobile homes , if its undersized for the load of the home a larger unit is needed , if I look at this one right here , it says this one will provide 3.6 tons of heat this size will only heat a small area (about 15x25x7 feet ) and wall insulation will help increase this too , also the wall thermostat will " cycle" the heater on an off due to demand , if its placed in a drafty spot then that will affect proformance as well
Jan 15, 2016 | Carrier Heating & Cooling
Furnace running but cold air coming out of vent!
There may be a dirty flame sensor, post the model number
Dec 20, 2017 | Goodman Heating & Cooling
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
Furnace is blowing cold air.
You must have an electric furnace, gas furnaces only come on when the heater is warm. Electric heaters come on with the use of a sequencer. Your sequencer, tstat, and blower is fine, which means you must have broken heating element. I have a nice pictoral of how to restring one HERE
Feb 21, 2011 | Carrier Heating & Cooling
Carrier Furnace infinity 96.model 58MVP060-F-18114. Furnace heats
Sounds like it could be your fan limit switch. Part costs about 20 bucks and is fairly simple to replace. This limit switch is a safety that prevents your furnace from over heating. Usually when your t/s is satisfied the blower runs for a little longer after the burners have stopped, and the reason for that is the limit switch. The blower is supposed to cool this limit switch to a certain temp. and once it reaches this temp it shuts the blower off. Yours is stuck:(
Feb 13, 2010 | Heating & Cooling
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
(HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Jan 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace completes cycle but the (24volts)wont keep the gas valve on.
Depending on which model you have there is a fan limit switch or a fan control or pc board that will bring the fan on once the furnace warms up some so that it doesn't blow cool air. This could be malfunctioning or the blower it;s self is malfunctioning which could be a fan relay, compasitor, or the blower motor it's self.
Sep 29, 2008 | Goodman Heating & Cooling
Carrier Furnace wouldn't light, fan was running all the time.
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
May 13, 2008 | Heating & Cooling
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
