Question about Toshiba 27AF45 27" TV
Color "burn" in corner
My Toshiba 27AF23 shows a strange color burn in the lower left corner. I thought my old amp/reciever was to blame because turning it on and off would affect the size of the color burn. It makes oranges appear purple and leaves blues unaffected. It also takes awhile for the "burn" to appear after the TV has been turned on...I've tried alot...Help!
    Problem Solver:
  • 5 Answers
If moving equipment and speakers away from the set does not help, try switching it off and the power switch (not just remote) for 30 mins. Most modern sets degauss even with the remote, but some sets only degauss (demagnetise) at full power up. If that does not help, see if leaving a strong bright image (like colourbars testcard) makes it worse after a few minutes. If so, this could actually be a tube fault in which case you might have to live with it. One other thing to try, at least temporarily, is relocating the set (switch off before moving it). Sometimes magnetism in the house, or even the Earth's magnetic field, can effect large screen sets.
Posted on Feb 03, 2007
    Scholar:
  • 168 Answers
Well i think this is caused by a magnetic field created by your speaker. is the speaker the same location for that color burn (lower left corner)? the only way to get rid of that is to remove your speaker or changed it. for all i know speakers used in tv's are magnetically shielded to prevent distortion in the CRT, because their location is usually near the crt. good luck!
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
Bottom left corner of my toshiba 65h83 is blurred with color distortion mainly magenta and green. Distortion Is a half moon shape with the open end facing the edge of the set. Total distortion takes up...
Have you tried the "Magic Focus" Button/Option in the Menu Setup Screen? If you have and it still is there, You Have a Burned out Color Tube. It is Cheaper to Throw it away and Buy a New one.
Good Luck..
May 12, 2009 | Toshiba 42H81 42" Rear Projection...
How to Access Color Wheel on Toshiba 46HM95
I bought a used 46hm95 but it had a greenish "band" that streched from the upper right corner to the lower left corner. It was only noticeable on a white or light colored background, which is why I overlooked it when I tested out the TV.
I took out the bulb and shined a flashlight into the color wheel. I could see a fingerprint smudge on it. I took off the lower rear plastic panel. the rear is split into two section (the light engine is on the right. You'll have to unscrew a metal guard (three scerws), then disconnect the wires coming from the left section, and then unscrew the plastic guard that protects the lens. Then unscrew the light engine (two screws) and slide it out carefully (you don't have to take it completely out, just far enough to reach the screws to the color wheel covers). There are two covers protecting the color wheel, one plastic and one metal. Unscrew the plastic cover first than the four screws to the metal cover. I left the color wheel in place while I cleaned it with a microfiber cloth. I did pull the glass square in front of the color wheel and wiped that down too.
I put everything back together, and now the picture is perfect.
Things to remember are:
*Keep track of the screws and where they belong, as you remove them so you'll remember where they go when it's time to put things back together.
*Mark the wire connectors from any wire you disconnect in case you forget where they go.
*Be gentle with the color wheel and the glass square because they are fragile.
Hope this helps.
Sep 25, 2008 | Toshiba 46HM95 46" HDTV
TV shows colored spot at the bottom left corner
The degaussing circuit has failed. Usually this circuit kicks in either when you turn the set on or off. This clears up any magnetic interference on the CRT. Toshiba sets usually have a 3 legged thermistor that controls this. I suspect that this part is defective. The parts cost for this is under $10. Check around for a servicer that can replace it for you.
Dan
Jul 28, 2008 | Toshiba 32A33 32" TV
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Faded colors
moniter colours changed what prabulem
Nov 22, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Toshiba 27AF45 27" TV Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
