Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
FAULTY SCREENS I HAVE 8 PANASONIC TH-42PH10MK HIGH DEFINITION PLASMA DISPLAYS WITH THE SAME PROBLEM.GREEN LIGHT GOES ON THEN RED ON FLICKERS 7 TIMES.DOES NOT EVEN DISPLAY NO SIGNAL PLEASE ADVISE
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
I had the same issue twice with a TH 42PWD5. turns out it was my UPS that was killing the switching power supply. Warranty covered it but when I removed the UPS not a single issue in 3 years.
Posted on Jul 01, 2008
  • 3 Answers
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Posted on Nov 25, 2008
djchillsnyc
  • 152 Answers
SOURCE: Flashing red light 7 times on our panasonic th-42pz700u
hello you have what you call a "shut down circut" it is for safety and when one of the internal boards gets shorted or is not working properly, service doc reads as follows
7 Blinks SOS:
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times
thiera blinking 7 times is cuase by a fualt in sc,su,sd boards
10th generation plasma service manual info
Posted on Dec 09, 2008
  • 21 Answers
SOURCE: TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Posted on Mar 11, 2009
Wont power on red light blinks
These blinks are fault indication. From the number of blinks occurs at one time switch on, you can get an idea about the faulty section circuit inside it. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Panasonic Plasma Displays are given in detail.
Apr 07, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a panasonic plasma TH-42PWD8 bought one 2 years ago but did not use it. Now i fixed it and started watching and then after one hour suddenly i see that the screen goes blank and the LED light to...
The factory diagnostic for an 8 blink error code is: Driver SOS 3 SS-Board / SS2-Board; SS FPC Detect; SS Energy Recovery Circuit. Basically it means that the current absorbed by the X-Sus board is too high. It looks like this
http://www.discount-merchant.com/PANASONIC-TNPA3544-X-Sustain-Z-Sustain-Board-p/1042654.htm
You will need to open the tv and check the connections to this board and all the components on it. Also check the filtering capacitors from the power output line that powers this board.
If you can't find anything wrong then the entire board will have to be replaced.
Aug 06, 2011 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
How do i replace the backlight on a Panasonic TH-42px75u?
Plasma displays do not have backlights. The ionized gas (plasma) in the pixels is the light source, just like a tiny neon light. If your screen is dim or blank, check the high voltage supply that ionizes the gas.
Dec 13, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
No picture power button blinks
We cleaned the dust off the fans and TV now works fine. Hardest part was getting the TV down and the back off to get to them. Thanks.
Dec 26, 2009 | Panasonic Televison & Video
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
