Question about Honeywell Heating & Cooling
I have a Honeywell Electronic AIR Cleaner model F50 F1099 and 2 of the nine wireson the right side of the cell broke while washing the unit. Can we obtain replacement wires?
  • 34 Answers
Yes, we have them in stock.  you can email TJ@BoanHeating-Cooling.com, he's our parts manager, he can get you the cost and availabilty of them. Chris
Posted on Dec 02, 2008
My Honeywell Type No. F50A Electronic Air Cleaner arced continuously even though I had cleaned it a few days prior. I shut the unit off and removed the air cleaner cells. Is it safe to run the furnace...
Yes you can run the furnace with out the electronic air cleaner for awhile.... It you are in a very dusty conditions than I would not run it very long a day or two....because you will not have any protection for dirty getting stuck on the evaporator coil or if you have a 90% gas furnace the secondary heat exchanger...and restricting air flow.... You can put in a 1" pleated air filter the same size as the total of the two cells in place of the cells till you can get the electronic working..... Sounds like either something big is caught across the cell plate or they are still wet and have not dryed out completely. Hope this helps.
Mar 02, 2011 | Honeywell (F50F1032) Air Purifier
I recently washed my Honeywell Type F50 cells and now when I turn on the heater, the "check" light stays lit and there is a continueos clicking sound.
washed them? how? i did not know that you were supposed to do that..can you describe what you did more specifically?
Apr 27, 2008 | Heating & Cooling
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
F50 air cleaner cells inoperative
Check for any of the metal layers in the cell to be touching or too close together. These units are very expensive to repair and to be honest the best option is to find a disposable box filter that will fill the hole.
May 01, 2009 | Honeywell Air Purifiers
I have a Honeywell in line electronic air cleaner (about 12 years old) have replaced/reworked the cartridges but for some reason the unit just stoped working. I don't believe that its the cartridges, do...
Steve,
Have some one check the power supply and transformer. Check contacts if it is the model I think it is they could be corroded, broke and/or bent....
Apr 26, 2008 | Heating & Cooling
I've got a Honeywell Environcare Elite filtration system on my furnace. How is the best way to clean these two units that slide into place and provide electrostatic cleaning? Can I soak in a laundry sink...
Honeywell Electronic Air Cleaners remove airborne particles as small as .03 Microns. To put that in perspective the smallest particle you can see with the human eye is 10 microns
Honeywell Electronic Air Cleaners have far more collection area to collect and store airborne particles than any other electronic air cleaner on the market.
Maintenance requires cleaning every two to three months. Located inside the unit are two pre-filters, which need to be rinsed off. The two electronic cells require a good rinse followed by washing them in your dishwasher.
Great for allergy sufferers.
This came from the link I provided below. Good luck.
http://www.americanairheatingco.com/residential/indoor_air_quality.shtml
Apr 19, 2008 | Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
