The vcr on camera bottons lioght up steel
SOURCE: jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
SOURCE: JVC GY-HD 110
I have had a problem with this. The first time I was setting up the camera I too couldn't get the computer to detect the camera. The computer will detect it before any program can begin to use it. I was using the pinnacle moviebox. I find that I have to use the cord only one way out of the camera and use the same end connected to the camera everytime and the other end into the moviebox or hardline into your computer. Believe it or not, i have to press the end into the moviebox good and snug otherwise it will not detect it. I also use a filter on the cable to stop any potential interference and a good indicator next time which end belongs in the camera and which one back in the computer. Since I have done this, I haven't had any trouble.
I connect the camera via IEEE 1394 with a cable with gold connections (10 bucks at target), into the pinnacle moviebox and then backout to the computer with USB into USB 2.0 port on my pc. My PC is running XP Media Center.
SOURCE: I'm using the JVC GR-DV500U model.When I turn on
Problem is this see the link just call JVC for free
repairs for CCD Sensors u get streaks blackouts and discolored picture
when CCD goes Bad no problem it is a known problem just call them in ur
region they will arrange for free repairs dont worry if u are out of warranty and ur model is not on list this is valid on all models thru out the world with same problem and pls rate me FIXYA for
help
http://www.jvc.co.uk/template.php?page=100102
SOURCE: JVC GY-HD110U won't turn on with battery power only AC power.
There is an issue with the a small yellow part of the AC plug breaking off in the camera. The camera thinks it's still plugged in, so it won't run on the battery. If you can get a small tool to fit into the inlet you can break the piece up and pull the parts out. I haven't had any luck with it, but read others doing it.
SOURCE: I DO NOT HAVE THE CD- SOFTWARE FOR MY PC, WHERE
staples, best buys, radio shack, an electronics store.
