Question about Williams 2509612 Ceramic Mid-Size Heater
Pilot adjustment on Williams wall heater
How can I adjust the size of the pilot on my Williams gas wall heater? The are the words "Pilot adjustment" stamped on the exchange block but no screw only a little round blue plastic insert with a pin hole sized opening in it. Maybe the flame is at what it should be but it seems too high to me. In the dark you can see small amounts of yellow flame along with the blue. The heater has two burners one for each side. It heats two rooms. The pilot burns in a Y-shape in order to feed both sides.
Thanks a million,
Scot
  • Anonymous Dec 28, 2008
    The Pilot is on when manually pushed in, and goes out when released to turn. Is it a defective part? What needs to be repaired?
The insert sounds like the cap covering the adjustment screw. Pin hole is for cap removal. Wondering why flame is so high?! Shouldn't have orange flame. If heater doesn't light with lower flame... thermocouple (thing that the flame heats up) may be bad.
Posted on Jan 03, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
I cannot adjust piolit light as I turn the adjusted screw
take the pilot line loose from the gas valve with a 7/16 wrench and blow air with a compressor through the tubing.then re-attach the pilot line USING YOUR FINGERS FIRST then snug it up.soap test it for leaks looking for bubbles.the pilot should be clean now.if not do it again.
Dec 18, 2014 | Williams Wall Heaters: 35,000 Btu/hr...
The pilot gas pressure should have been preset at the factory. If an adjustment was needed at the time of the installation (or after the replacement of the gas valve if it was ever replaced) the installer should have set it. Assuming all of this was set proper at one time you probably only have a dirty pilot assembly. The assembly should be removed and cleaned thoroughly. The pilot orifice inside the assembly is probably restricted with dirt.
Low Pilot Light on Williams Heater
With propane, the hole should be tiny. The manufacturers instructions would say what size according to your elevation and BTUs. But, in order to get more flow, I use a small sewing needle to ream out the hole, very very carefully twisting and pushing. I grip the needle with small vice grips. Take care not to break the needle inside. Increasing the size of the hole just a tiny bit will dramatically increase the pilot flame size. Before you do all that though, try pressurized air, just cleaning the pilot tube and the orifice could be all you need.
Apr 02, 2014 | Heating & Cooling
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
Pilot flame burns above pilot tube in propane heater. the sensor does not register. the pilot top of the tube shoul glow red. I have cleaned the tube, in few occasions it has lit and worked for above 10 to...
Hi it there a leak on the pilot causing it to burn that high can you adjust the pilot gas going in to the pilot ?
have you cleaned the pilot injector out or is the hole in the injector too big
Jan 25, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Heater will not stay lit!!!
Lets start with safety. Check your vent pipe for obstructions, mainly outside at the vent cap. The safety of this unit will not allow it to operate if there is anything blocking the vent. If all is OK, then next we will light and observe the pilot with it on the pilot setting on gas valve. The pilot flame should consume the tip of the generator point by 1/2 to 5/8". If it does not, then screw off the pilot adjust screw cover on the gas valve. This is clearly marked on the top of the valve. Inside you will have a much smaller screw. Turn it counter clockwise to raise the pilot level, clockwise to decrease. Never consume more than 5/8" of the generator tip. Hopefully your problem will be resolved here at this step. If however it is OK, then take a millivolt meter and read the generator millivolts, at the gas valve with the thermostat contacts closed. It should read 140 millivolts. You need this much power to properly operate the heater. If it is lower than 140, then replace the pilot generator....Rob Just a note...Do not remove or take apart any part of the Gas valve, other than the pilot adjust screw cover...Good Luck.
Dec 29, 2009 | Williams 3003622 Ceramic Wall Mounted...
Heatilator Pilot Issue
Any pilot adjustment would be under a large screw with a flat blade slot in it. There would be a smalled flat blade screw under it. Warning: Too small of a flame and your safety device won't work.
READ MORE
Jan 04, 2009 | Williams 2509612 Ceramic Mid-Size Heater
i'm having the same problems.......................
Oct 21, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
1,532 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
