Question about Performance Teknique ICBM-9840 Portable DVD Player without Screen
Picture, no sound for my Performance Tekniques ICBM-9794
I bought a Performance Tekniques, model ICBM-9794 and I hooked in up in my vehicle the video is great remotes work on screen works, everything except the sound, fiddle with the wires changed them around and still nothing, along with that I bought 2 cordless headphones,(assuming a related problem), they won't work either I am getting radio stations, so the headphones themselves are working but not inconjuction with the dvd player and monitor, what can I do to fix this problem??? Thanks
SOURCE:
Cerfer39
  • 709 Answers
SOURCE: Performance Teknique ICBM-774
It is almost obvious to me that the New Box is Unvented. If you went from Vented to non-Vented. there you go. The Amps and Subs should be doing the same thing. If your Sony 10's are designed for Vented they will not thump right in a NON-vented box.
Posted on Nov 30, 2007
  • 631 Answers
SOURCE: Performance Teknique wont work!!
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
If you want to try to repair it yourself, read through the following page:
Basic Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Jul 02, 2008
  • 631 Answers
SOURCE: performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Posted on Sep 11, 2008
blueextc3221
  • 15935 Answers
SOURCE: ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Posted on Dec 22, 2008
SOURCE: i lost user manual for Performance Teknique ICBM-9493TV Car Video
Yo I have a icbm 5254 in dash monitor and in order to bypass the parking brake security, splice the wire that's marked "park brake"(mine is Pink, yours may be Orange,but it'll be the oddball colors) into the acc or aux wire(usually yellow) and it'll play dvd while moving. Hope this has been helpful.
Posted on Aug 29, 2010
Icbm 9529 performance
Spell out the words please. The times make that acronym disturbing. Thank you.
Jul 22, 2014 | Performance Teknique ICBM-9529 GREY
Need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
I have the same sub on the "digital" amp from the same company.
I used the 1.75 ported box from my jl 12w3v3-4 and it sounds great. I am not sure on the correct box size but the box for the 12w3 sounds great. I tried emailing performance and the email was wrong.
Feb 26, 2012 | Performance Teknique ICBM-5912 Car...
Hey I just recently buy a performance teknique
good luck finding one, check ebay, or call Teknique directly.
Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
What parts are needed for my performance teknique icbm-9500t
first of one,work start of full effort.in the problem situation no sad.
Nov 30, 2009 | Performance Teknique ICBM-9500T 7" In-Dash...
Keeps on diagnostic after i turned it on and had it completely wired what should be the problem
have you checked the power ant wire? usualy oarnge this needs to be hooked to a power source that is not on when the power of your vehicle is not on (usualy a fuse block)
May 11, 2009 | Performance Teknique ICBM-895 Car Audio...
I lost user manual for Performance Teknique ICBM-9493TV Car Video
Feb 28, 2009 | Performance Teknique ICBM-9493TV Car Video...
Not enough power delivered
This sounds like a gain setting problem on your amp. The best way to adjust is to set your volume on the head unit to about 75% volume and then adjust the gain up until it sounds distorted a little. Back it off jst enough for the distortion to go away and you are set. Only other thing to try is use a multimeter set on Ohms to test the resistance of your speaker configuration. Looks like 2000 is th peak power (not RMS) and is only possible at high current configurations. You are probably running at 4 Ohms, but this amp only puts out rated power at 1 ohm stereo or 2 ohm bridged. Many people say Performance Technique are overrated, so maybe not even what it is rated at - 350 x 2 @ 2 ohms bridged (probably only about 175 x 2 at 4 ohms bridged)
Feb 06, 2008 | Performance Teknique ICBM-9540 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Performance Teknique ICBM-9840 Portable DVD Player without Screen Logo
106 people viewed this question
Top Performance Teknique Televison & Video Experts
Marvin
Marvin
Are you a Performance Teknique Televison and Video Expert? Answer questions, earn points and help others
