Question about True GDM-41 Refrigerator
SERVICE MANUAL CAN YOU TELL ME WHERE I CAN GET A SERVICE MANUAL FOR A SAMSUNG REFRIGERATOR MODEL NO RB1955SH
  • 700 Answers
  • Steven Jun 15, 2012
    Page is no longer available.
Service manual for refrigerator Samsung model: RF32FMQDBSR
Request the service manual directly from Samsung.
Aug 10, 2017 | Samsung Refrigerators
Bottem freezer drawer rails
You need a service manual. My refrigerator is a different model. A diagram for installing the freezer tub rails or other installation of the parts might be found in the service manual of your unit. You can check the availability of the service manual from Samsung's authorized parts distributor. You can get this information in two ways - online and by phone. Have your model number ready for either option. You can order the manual over phone by contacting Samsung's parts distributor, Samsung Parts, (also known as J&J Parts) at 1-800-627-4368. Hours of operation: Mon - Fri from 9:00 A.M to 8:30 P.M EST.
Nov 02, 2014 | Samsung RF4289HARS French Door...
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
I got a samsung refrigerator model rs2534ww control panel has a blinkin light. and is not working
Sounds like you just need to do a reset, press and hold the top 2 buttons till it flashes then let go. If you hold it to long it will run a diagnostic mode and may lock up on the blinking light again. The blinking light is a trouble indicator for the service tech. It tells them that sensor or heater is faulty or will point them in the right direction. I found a repair manual on the online auction place E b a y that can help you troubleshoot further but have not bought it as of yet. I just purchased my Samsung and was reading some reviews to see what kind of problems i may run in to.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
I need a service manual for a samsung refrigerator RB1855SL
This manual cover 4 models like yours. If I try to open just the model number I get compressor. By choosing the highest level of the model you have I needed to cover that series. Confused. No problem this is the manual for your model=> RB1855SL If you need more assistance please contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 16, 2010 | Samsung Refrigerators
Beeping
basically its telling you that it's not maintaining the temperature that you have it set for. if indeed you do have this particular model number contact me and i have the service manual for it.
Jan 06, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung rb1955sh
if you hold the two top buttons on the right and left side of the display for 4 to 5 seconds it will reset the control board and it should restart, if not check the door switch for a bad connection. I had the same problem and i cleaned the contacts on that switch and reset the controller and no problems since. (2 months and counting!)
Dec 20, 2008 | Samsung RB1955VQ Bottom Freezer...
SAmsung Service Manual
I fixed my problem with the fan not working in the refrigerator section. It ended up being the fan motor. The way I nailed it down was to temporarily switch the wires to the fan motors in the connector on the circuit card. This electrically powered the freezer fan from the refrigerator side and visa versa. The fan still worked in the freezer side (running of the refrigerator circuit) and was still inop on the refrigerator side proving that there was nothing wrong with the circuit card or possible other factors driving that circuit (other than the fan motor). I ordered and installed a new fan motor (about $50) and now everything works fine. It seems that the original problem caused the circuit card to shut down voltage to the bad fan motor that's why when you checked the voltage from the circuit card, it was nill causing you to falsely believe that it was not the fan motor. Yes, I did a resistance check on the fan motor and it was very close to being the same as the freezer motor (same part number).
Jun 03, 2007 | Samsung RS2630SH Side by Side Refrigerator
True GDM-41 Refrigerator Logo
402 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
