Question about Canon PIXMA MP830 All-In-One InkJet Printer
Poor photo copy when printing 4x6 glossy in cassette tray.
When printing 4x6 glossy photos from cassette tray, excess ink and smearing on photograph, with lines. No problem with printing via auto sheet feeder, but not sure how to print 4x6 size there. Performed nozzle check - all ok. Did bottom cleaning and cleaning print nozzles even though not indicated. No improvment in quality. Can you help?
    Scholar:
  • 134 Answers
Set the Ink Intensity (Windows) The Intensity setting controls the amount of ink placed on the paper. The higher the intensity the darker (more ink) the printed image will be. If the Intensity setting is set too high, the printed page may become too wet and curl or streak. Follow the instructions below to adjust the ink intensity settings.
  1. Access the printing preferences by opening the printer Preferences / Properties.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. On the Main tab, select 'Manual' for 'Color Adjustment', and then click 'Set'.
3.Use the slider bar to adjust the 'Intensity'.
Note: Move the slider bar right to darken the image, and move the slider bar left to lighten the image.
Click 'OK' to complete the setup.
I hope it helps!!!
Posted on Dec 02, 2008
When I print a glossy photo print, right at the end the printer makes a noise as if its labouring and there are excess ink smudges on the corners of the print. It only happens when printing glossy paper.
i think the problem is with your print head. i have the same problem before. when i put out the print head to check. there's a lot of excess ink. this may be the reason for the ink smudges on the corners of your print. and when you set your printer to photo printing. it is programmed to put larger amount of ink than normal printing. the best way is to have your printer checked by your service center or change your printhead to a new one. goodluck!
Apr 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Samsung CLP 510 - won't print on photo paper.
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
Aug 31, 2008 | Samsung Office Equipment & Supplies
4x6 photo paper won't feed into printer after I put paper in the tray it says to put glossy side down and I have done that. Do I need to clean a roller or something?
Click on "File" then click on "Print" in the dropdown
In the Print window click on "Paper/Quality" then change "Main Tray" to "Photo Tray"
Apr 07, 2011 | HP Photosmart C8180 All-in-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Only 4x6 tray prints clearly
For this concern try pressing "copy+cancel" for media calibration then try again, make sure you have an A4 paper loaded. If this doesnt help you out try using the Kodak website www.kodak.com/go/itg and use "image quality" for class.
Oct 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing onto photo paper from mac g4 computer
I put the 4x6 in the bottom cassette. I place it with the shiny side down. Landscape is when the 6" length is front to back in the tray.
I use the cassette exclusively for 4x6 and use the back tray for all else. It works great.
Apr 20, 2008 | Canon MP610 Photo All-In-One Printer
Horrible print quality
hi i am a certified Canon repair tech for this printer. the first problem is the paper you are using hp photo paper is specialty formulated to be used with there inks. every manufacture is the same if you want the proper looking photo and you are using a Canon printer you need to use Canon photo paper because the paper is formulated for their inks. hope this helps to clarify.
Jan 04, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
73 people viewed this question
old marine
old marine
