Question about Samsung LE40R74BDX 40 in. LCD Television
I have just bought 26" umc tv and need to get stand off but cant find screws to remove it
  • Anonymous Dec 16, 2008
    i can't get the stand off either, it's the 26" umc combi lcd tv & built in dvd, the instructions say unscrew 2 screws on diagram...they don't exist? did you find out how to do it yet? please help
HI
It is not 2 screws as the instruction says it is a row of 3 screws,
It took me a while to work this out as well The 3 screws are easy to see.
Posted on Jan 03, 2009
  • alanzyx Sep 27, 2010
    Yes, the manual fooled me too. It is 3 screws, and when you've done it once it's obvious.
Can I buy screws to fix base onto my umc tv
Yes The screws that you took off the back of the tv mount on wall brackects mounted on the back of your TV should be the same size
6mm
Oct 23, 2014 | Televison & Video
HOW DO YOU GET THE TV STAND OFF A UMC UX26A TV
Check the tv back cover at near around the base stand area.Lacate all screws near or at the base stand,spray some WD40 in each screws holes and wait like around ten mins.Take a Philip screw driver take out all the screws out in the srews holes.Take ur hand slicely push it foreward and pull it back.Now u should have no trouble taking out the base stand.
Dec 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
Need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
May 26, 2009 | Niko OTP-2613W 26 in. LCD Television
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
May 20, 2009 | Insignia LCDTV26 26 in. Television
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
Jan 04, 2009 | Soyo DYLT032D 32 in. LCD Television
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Samsung LE40R74BDX 40 in. LCD Television Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
