I have a Seagate 80GB drive (ST380215A Barracuda 7200.10)which I have tried to instal in place of the original 20GB drive. The PC doesn't seem to recognise the drive when BIOS is set to "AUTO". I therefore wish to set the parameters manually. The drive does not give this information on the case, and I can't find it on the Seagate website. I need to know the number of: Heads, cylinders, sectors etc. Can you help?
  • 1 more comment
  • Webshot Dec 02, 2008
    Thank you crayzeetrayn. The jumper is set for master, identical to the 20Gb drive, and the drive is at the end of the ide cable with nothing else on it.
    I cloned into the 80GB drive through an external USB set-up, and then did a straight swap with the 20GB drive. But it doesn't seem to be identified and refuses to go past the hard drive check stage during the boot.
    There is an 80GB drive option in the BIOS, but the built-in parameters don't appear to be appropriate to the Barracuda, hence my wanting to insert the parameters manually.
  • Webshot Dec 03, 2008
    Hi crayzeetrayn. I'm new to this site and it would appear I've locked myself out of the discussion without realising it, so I'm sending this under "I have the same problem"
    The PC is an old HP model with an MS6166 Ver 1 motherboard, having a slot 1 pentium lll, 800 Mhz CPU. I've just replaced the motherboard, which works OK with the original 20GB drive, using Xp OS.
    Every time I replace the 20GB drive it boots and works OK, so that seems to check out the cable and board interconnect. I also tried the 80GB drive prior to cloning, and that was also unsuccessful.
  • Webshot Dec 09, 2008
    I'm sure you are right. I did look for a BIOS update, but so far I haven't found one. It is possible that there is not one available for a motherboard of the age of mine. I'd still like to try putting in the drive parameters manually, but can't seem to find those quoted anywhere. I find that very puzzling!
    Novelist:
    Champion:
  • 233 Answers
Is this a new or used HDD? If it is used maybe it is bad. Is LBA enabled in the BIOS? Maybe try the secondary IDE BUS. Also try connecting it to the first connector on the IDE BUS rather than at the end.That is all I can think of right now.
Posted on Dec 29, 2008
  • 837 Answers
How do you have the jumper set .. Slave, Master or Cable select?
I have a Seagate 80GB - moz-screenshot.jpgIs there another device on that ide cable (i.e. cdrom, dvdrom etc)
Be sure that it is not conflicting.
Match the jumper settings to your 20GB that you are replacing.
Posted on Dec 02, 2008
  • 2 more comments
  • Jay Glendenning
    Jay Glendenning Dec 03, 2008
    What is the make/model of your pc?
  • Jay Glendenning
    Is it not seeing the drive at all? Check to make sure you didnt work the connection loose off the motherboard.
  • Jay Glendenning
    Jay Glendenning Dec 09, 2008
    I would look for a BIOS update .. I think you have a BIOS problem preventing you from "seeing" the 80GB
  • Jay Glendenning
    I have searched quite extensively for a BIOS update for you and/or a drive utility that wold allow you to use your 80GB but haven't been successful. Sorry.
How can I convert a Seagate Barracuda 7200.7 (Model st380011a) to an external drive with usb?
BUY A HDD ENCLOSURE (http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=2777&name=Hard%20Drive%20Enclosures)
Apr 09, 2012 | Seagate Barracuda Model ST380011A 80GB IDE...
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Hi, My Seagate 80GB IDE HDD is not detected in BIOS. But the drive is spinning. Is there any way I can recover my data?
If data in your hard drive is really important to you, try to look for a similar model hard drive. Then swap the logic board of the good hard drive with the defective hard drive. If the cause of problem is the logic board, then your hard drive should work by now. If you are not that technical, you can ask a technician to do this for you. You can buy a second hand hard disk for a few bucks at ebay.
Dec 28, 2010 | Seagate HD-ST380215A Barracuda 7200.10...
My hard disk capacity is 80GB. It is seagate barracuda 7200.9, it is showing 32 gb instead of 80gb. I dont know how to fix this, but reading some experts answers i came to conclusion that this is a jumper...
Indeed. The problem is that you put the jumper and it limited the capacity of the hard drive to 32 gb.
Here is a picture that will help you put the jumper in the exact place:
Mar 21, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to check the warenty period of segate harddisk
Here is the site on Seagate that will help with your warranty status.
Click Here
Jun 01, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Bad sector affecting partition resize
You don't. Replace the hard drive if you value your information.
Apr 30, 2008 | Seagate Barracuda (ST380215A) 80 GB IDE...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
