Question about BafoTech 1 Bay BAFO BF-2010 Storage Cabinet
BAFO BF 2010
My bafo BF2010 is not working... i need help. it doesn't have any whacked up part... (burned, or swollen capacitors) the fan is working... green lamp is ok when i switch off and the red light when on. Im using the USB port connected on a winxp computer (Pentium4 2800mhz) the Jack is OK (I have 2) the problem is that i never have response from my computer that a new hardware is connected. (no notice or anything.)
    Problem Solver:
  • 14 Answers
I also have a BAFO BF-2010. I'm looking for the drivers and have sleuthed the file names, so you or others can try and track it down. If I find a site I'll comment again with answer. Bafo BF-2010 drivers Windows: 2010USB.zip Mac: MacUSB0803.sit
Posted on Aug 28, 2011
  • jopower Aug 28, 2011
    I just tried the FireWire ports (not USB as before). WinXP (sp3) picked the drive up in seconds, no driver required (VIA chipset in my 7 year old laptop w/FireWire port). Transfer rate very fast compared to what USB 1.0 would be. Also finally found my OEM drivers... on the old drive I'm testing ;^D. Turns out the NT/XT driver is buggy for USB anyway. Finds then dismounts the USB connection intermittently. Very unreliable. New cable makes no diff. I would like to upload the driver and manual PDF but my previous "Solution 2" both removed the "add solution" window and the option to do anything else but post this comment. The FireWire device is found in "Control Panel > System > Device Manager" reports the device as "SBP2 Compliant IEEE 1394 device". The driver is (2001) 5.1.2600.5512 version of "sbp2port.sys". So, the best solution is to dust off your FireWire port or drop in an old FireWire card for under $10 from your local PC shop's surplus box. Happy Transferin'!!
I,ve just put a hd ut to 320 gb and my bafo doesnt work. Before with a 160gb worked wery well with fire wire it seemed fast too. Help pls
Posted on Feb 02, 2008
    Bafo BF-2010 drivers for..... Windows: 2010USB.zip Mac: MacUSB0803.sit
I have mine, it works well but in a very slow data transfer. I looks like it is made for the very first version of USB, I havent tried the firewire yet. Try to go to add new hardware and install the driver that comes with the package. I am also using windows xp.
Posted on Jul 03, 2007
SOURCE:
I have bafo-bf-1284 usb to parallel converter but i don't have driver cd. problem creating to install this product in windows 7 or windows xp please help me.
The BF-1284 driver (zip file) is available from BAFO support: http://www.bafo.com/menu-support.asp . Scroll down the list to the desired product. The driver is for Win98se and Windows Me. You shouldn't need a separate driver for Win7; the drivers should be in the OS. (See the link on Windows 7 compatibility near the top of the URL given above.) I suspect the driver should also be available in the OS for XP.
If your computer doesn't find the driver automatically, check if the driver is listed in Windows Update as optional updates. (You may have to manually check for updates.)
I hope this helps.
Jul 30, 2011 | BafoTech BAFO BF-1284 Parallel Adapter
I am not able to get BAFO BF810 to get working on Windows XP SP3 - dont they have drivers for SP3? It works on SP2 though.
here is a linkt to the BAFO support site the drivers listed for your USB serial adapter the driver is listed for XP, Vista and Windows 7. As SP3 came out before Windows 7 I think the driver will be compatible with XP SP3
here is the link to the driver download
http://www.bafo.com/download/Driver/PC/BF-810%20DriverInstaller_v1210_windows.rar
Feb 24, 2011 | Office Equipment & Supplies
Windows 7 64 bit Is not installing drivers for BF810
Here are the drivers you need for your USB to Serial adaptor!
~KenjiFox
Jan 07, 2011 | BafoTech BAFO BF-810 Serial Adapter
Can I get the BAFO BF-8011 to work on Windows 7?
It is NOT Compatible. It would only work with 98SE, ME, 2K and XP.
If you wish, you could Download the manual as well from :-
http://www.bafo.com/download/2007_download/BF-8014/8014_98ME2KXP_v1.3.zip
You need to have Acrobat Reader to View thee File.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 31, 2010 | BafoTech (BF-8011) Bluetooth (BF8011)...
Hi.. i can'nt find usb vista driver for my bafo-2010.
hi..
thnaks for your concern , i remove my HD and add it as second IDE on my PC.
For the BAFO BF-2010 Storage Cabinet i found it not useful becase this is not the only problem i have, as it also detect 1 partition only so i decided not use it any more
Feb 27, 2009 | BafoTech 1 Bay BAFO BF-2010 Storage...
Bafo bf-1284 can't detect
I need a driver for BF-1284 in windows xp
Aug 29, 2008 | BafoTech BAFO BF-1284 Parallel Adapter
Reqd Software for BF-810
Go to
this page at Softpedia.com
and follow the link to download a free copy of the driver for the BafoTech BF-810.
Mar 17, 2008 | BafoTech BAFO BF-810 Serial Adapter
Bafo BF 2010
Yes, it does: Mine worked well with a fire wire and Hd of 160 gb maxtor: Now I,m trying with a 320 gb western digital and I 've the same problem you have. try again, it must work
Aug 21, 2007 | BafoTech 1 Bay BAFO BF-2010 Storage...
Problem with BF-810 usb to serial
windows xp can not install a driver for bf-810 adapter.
Dec 17, 2006 | BafoTech BAFO BF-810 Serial Adapter
BafoTech 1 Bay BAFO BF-2010 Storage Cabinet Logo
373 people viewed this question
Top BafoTech Computers & Internet Experts
 Mike M
Mike M
pankaj rautela
pankaj rautela
Are you a BafoTech Computer and Internet Expert? Answer questions, earn points and help others
