Thermo Compact Vaillant Boiler
I have just bought a Thermocompact 628E boiler, someone told me i cannot have it installed as its obsalete can someone tell me if this is so. Also i was told that i need an un-vented water cylinder as well is this so. Please get back as soon as. my health is not good from recent heart attack and its freezing in my house as old boiler packed up.
The thermocompact is a non-condensing model, and should be o.k to fix, you do not need a cylinder as is a combi model and would provide hot water on demand!
Posted on Feb 04, 2010
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
I have a Vaillant Thermocompact VU182 E boiler. Functioning ok except that when room stat. or cylinder stat.shuts of gas the demand light continues to glow and pump keeps on running. Main switchboard has...
Pump should keep running long after gas shuts off, because of residual heat. It is most efficient to shut gas off as quickly as possible, and run off retained heat.
Oct 13, 2013 | KDS Valiant 6380iPTD-01 Notebook
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
Lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler pressure up at 3 bar and need to try to repressurise
may at the back outside casing can be pressurised by footpump if required
Oct 12, 2009 | Water Heaters
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Vaillant boiler that supports a time switch 110
Vaillant time switch 110 have always been problematic. Dry joints on circuit board and faulty clocks.
They seem to last from 2 months to 3 years but can be bought for £33.70 inc VAT from https://supreme1.sslpowered.com/cgi-bin/DMdatabase.cgi?action=/mnt/w0502/d01/s11/b009fa92/cgi-bin/home/Shop/Boiler_Accessories/Vaillant.txt&item=00038
Hope this helps
Jan 26, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant thermocompact 628E gas boiler - not working. Seems as though no power getting through. I had a to replace a switch where some drops of water had leaked into that supplies the power to the boiler,...
Dear Prockie..
First, find the wiring diagram and a voltmeter. Attach one lead of the meter to a good ground. Then trace the voltage as laid out on the diagram. For example, if you have voltage to a switch or device, but no voltage out, then that device may be defective. Check all connections. Your boiler has "self diagnostics" but with no display a simple power problem is indicated. If you have no wiring diagram check with the manufacturer online.
Ray
Nov 15, 2008 | Heating & Cooling
Heating & Cooling Logo
376 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
