Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
Ariston AML125 won´t spin or empty water.
When the program reaches spin the buttons start blinking and it just stops. The water won´t empty out, so i have to unplug it to open the door. Then the clothes are not rinsed (they are still soapy, and of course wet)
  • Anonymous Mar 12, 2014
    Machine spins, but water won't come out
  • Anonymous Mar 26, 2014
    Won't spin dry clothes
    Problem Solver:
  • 5 Answers
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Posted on Feb 07, 2009
  • Ariston Tech... Master
  • 3,463 Answers
Try laying the outlet hose down and let the water run out, then try spin again, if it spins then problem is related to pump.
Posted on Dec 02, 2008
Why won't my Splendid Ariston washer spin during a regular wash cycle?
Remove the kick plate from the front of the machine and you will find a removable screw-in bung. Put something underneath to catch water. When you remove it, you will find a plastic toothpick in there which is jamming the pump impeller. The safety feature stops the machine spinning if the pump is not working.
Splendid Ariston Google Search
Jan 03, 2017 | Washing Machines
The cycle stopped with 2 minutes left. It stopped spinning and had an inch or so of standing water. It was making a clicking sound. I hit the pause button and it would not cut off. I unplugged it and set...
as far as the standing water, try to reach the water pump to remove the button or other things that dropped out of you trouser pockets stopping it from emptying properly, as there is still water in the tub the machine wont move on till its empty eric
Jan 18, 2018 | Whirlpool duet Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
Water not emptying from the machine,
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
May 16, 2010 | Ariston Technologies Ariston AWD12 Front...
Can I connect my AML125 to hot water
Not advisable if it is a cold fill washer only, as you will then be rinsing in hot water, and this could cause shrinkage of clothing and other adverse effects..
O/k if it is hot and cold washer.
Plz rate my solution.
Jan 06, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
I have an Ariston Magherita 2000 it stops and the dial keeps going around when it gets to the spin. If I then put it back on spin it will not drain the water out. If I empty the machine and then put a...
unplug machine from power.
pull the front panel off of the machine its at the bottom, kind of snaps off bottom first then top eases out, anyway becareful as it is pretty fragile plastic.
On right hand side unscrew filter cap - prepare for lots of water that really stinks to pour out. Cap can be a fiddle but does release after unscrewing anti clock wise.
Put fingers in and clear out any blockages you can see, mine was a 1 pence peice and a hair tie. Put back together and it should be ok.
Jan 01, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
1,257 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
