Question about HP PSC 1510 All-In-One InkJet Printer
Faulty scanning found as full-black sheets or scratches throughou
When I make a scanning, the Preliminary Scan shows the page in black or with random scratches throughout the document. It does not recognizes images or documents at all.
I think it has nothing to do with the crystal cleanliness as it seems to be in good condition.
  • 81 Answers
Sometimes, the ribbon cable connecting the scanner reader to the main board get loose, giving garbage readings.
try opening the scanner and get sure the cable is properly attached.
if that does not fix it, you probably have a main board issue, which is very difficult to fix.
good luck
Posted on Dec 06, 2008
Black vertical line when copying a book page.no light leaks.
If it is along the edge of the print, it may be the edge of the book page you are seeing. if it is going through the text of the page, your scan carriage is likely skipping. If you don't see this on copies of single sheets of paper laid on the glass, then the weight of the book may be deforming the glass enough to catch the scan carriage as it passes. If you see it on single copied sheets, there is probably something on one of the scan rails under the glass that the carriage is "hopping" over as it passes. You could try watching the scan carriage move while holding the lid open to see if the carriage "hops" once during a scan.
Nov 10, 2013 | Panasonic KXMB2030 AllInOne Printer
Copying a document prints out black page
Its CCD(scan camera) unit faulty, replace it..see the idle snap shot
Jan 09, 2012 | HP Officejet Pro L7680 All-In-One Printer
Windows 7HP and Epsom BX300F can scan but preview shows that, one a4 sheet is split into 4 or 5 random areas and will print those areas only on 4 or 5 seoerate sheets of A4. How do I change this so that...
Goto -> Printer's Property/ Prefrences 1 - "Layout" Tab -> Select Portrait in Orientation section. 2 - "setting" Tab -> Select A4 in Paper Size DropDown. 3 - Click OK and try.
Feb 16, 2011 | Office Equipment & Supplies
Do you have a source for the programming instructions for a "7 Day Digital Timer" model EM0101 Thank you, Chris
I have a scanned copy of original Instructions for EM0101 7 day timer. But I don't know how to transfer it to this site w/o showing an email address. It's 2 full pages with display diagram.
Oct 19, 2010 | Kitchen Appliances - Others
Black page printwhen I try to copy or fax from my hp 6110 printer
The printer isn't shot, but the scan assembly is, it sounds like either the scan lamp is dead or the sensors in the scan assy. You should also be getting a scanner error. I would try the reset, powering up with either the #3 or #6 buttons pushed, and see if a reset helps.
Jun 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Won't scan full page
In the control panel for the scanner, on the bottom left is a button labeled "Specify," where you can adjust how much of the page it scans. Sometimes it is "auto-detect," sometimes it is the size of a small photo, sometimes it is full page. You just have to set it to what you want. Usually auto-detect works, but sometimes it misses and only scans part of a full page, so you have to set it manually to full page.
Apr 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Scanning sheet music
Scan all pages with GrayScal Single Page JPEG and then convert them to Multipage PDF.
Jan 22, 2008 | Canon CanoScan 8000F Flatbed Scanner
Scanning Different Sized Sheets
There should be a preview option that scans more quickly than actually scanning the page. Then after the preview shows, you can select the area that you want to actually scan and then you hit the Scan button. If you are using the Canon software, this should work for ya.
Nov 07, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
HP PSC 1510 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
