Question about Krups XP 4000 Espresso Machine
Krups xp4000 express machine
There must be a safety type mechanism as part way thru the brewing process it pops and water leaks around the brew head
SOURCE: Krups XP4030 is stuck in the steaming mode
Here is a link for the manual. It says on Krups web sight they have a 1 year warranty,
http://www.krupsonlinestore.com/manual/55360.pdf
Posted on Jan 10, 2008
SOURCE: My Krups won't brew
had the same type of problem with a hair dryer once. A thermal interrupter- I called it a planned obsolescence gizmo- died. I bypassed it with a silver wire soldered in and the hair dryer ran well until another part died years later!! Sailorb
Posted on Sep 14, 2008
nielele
  • 11 Answers
SOURCE: Krups 229 Aroma control switch is broken
Hi john you need to replace circuit board that has timer and auto shut-off I have same problem krups doesn't think it is a safety issue because the coffee maker has a thermal switch. But I still think it is. Also if you are not carefull when you fill with water it will staem back in your face!
SmallAppliance.com has special order replacement boards.
I will be replacing mine
Posted on Aug 10, 2009
  • 39 Answers
SOURCE: I have a Krups xp2070 that sends hot water to the
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Posted on Dec 30, 2009
Testimonial: "Thanks! Very helpful. Now we can (probably) solve a problem that will bring espresso back into our lives!"
  • 22 Answers
SOURCE: Krups KM7000 grinds but won't brew, warming plate
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Posted on Jan 31, 2010
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Mar 22, 2014 | Keurig Coffee Makers & Espresso Machines
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
I own a Breville 800ESXLespresso machine which i already decalcified, that leaks from brew head and handle moves while brewing
If you've had the machine for a while, your brew head seal (gasket) is probably damaged or shrunken from age/heat and needs to be replaced. That's most likely why the filter holder moves and leaks while brewing. Breville brew head seals are rather difficult to locate, but I personally stock them and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Nov 27, 2010 | Breville ESP8XL Espresso Machine
Coffee not coming out of the front taps, coffee & waste beans both ending up in the waste tray, can you please advise thankyou. model type 889
I had the same problem. The pipe that delivers the coffee brew is plugged, therefore, the brew leaks back in the waste tray. You need to take the top cover only. Then you will see a silicone hose. You need to pull the hose out of the head pipe. You can remove easily the head pipe as it snaps on the pipe that delivers the brew. What I did was to run the descaling program. Then inserted a thin stiff wire during the cleaning process and gently pushed the wire a few times to remove the obstruction. You have to be careful. Once the obstruction is cleared steam or liquid will come out of the pipe with some pressure. Then stop the cycle and run it again once the head pipe and top cover are replaced. Although there are no electrical wires visible when you take the top cover you need to be careful and wear rubber gloves and goggles. This worked for me and it was probably due that the machine was not used for sometime and the coffe brew plugged the delivery pipe. Good luck
Mar 01, 2009 | Krups Orchestro 889 Espresso Machine
Hi, I need a 'joint seal' for my Krups XP4000 expresso maker, and ideally also one for my old Krups XP 962 expresso maker. I got them in France where they are called 'joint porte filtres' ref cde MS 620342...
The part for your XP4000 is the brew head seal. A Google search turned them up here:
http://www.smallappliance.com/product.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&pid=2870&prdCls=P&shopBy=Brand
This page is their Krups model list:
http://www.smallappliance.com/department.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&shopBy=Brand
It doesn't show the XP962 but it gives their phone number and says to call if you don't see what you need. So maybe they can help.
In general, when you want to search for something on the Internet, start with a good search engine (I use Google but there are others of course) and give a search string like "krupps kp40000 parts". Then you can check out the links it gives you until you find what you need.
Nov 22, 2008 | Krups Small Appliances Espresso Machine
Krups xp 4020 leaking
My Krups leaks like a sieve and I found parts (seals) available at  smallappliance.com
Sep 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
