Question about Indesit Door Handle Kit for W123, W133, W143, W161, W83, W93 Washing Machines
Indesit w123. motor burnt out?
Hi the dial clicks round and it flashes twice, I have checked the brushes and they seem fine, it drains ok, just nothing else, would I be right in thinking the motor has burnt out? Thanks tim
  • 2 more comments
  • mitgninnug
    mitgninnug Jun 18, 2012
    Hi, sorry I wasn't very clear, the flashes (2) come from the power light, which indicate an error code and two mean something to do with the motor but as the brushes are still ok and it only fails when it tries to turn the drum I was thinking it may be a dead motor, the machine is at least 10 yrs old and gets used slot ( family of 5), thanks
  • mitgninnug
    If I put it on a normal cycle, it fills and then as tries to start turning, starts clicking round and drains. If I try to spin it just does a drain and then starts clicking round. I've taken the top off and nothing seems burnt in the electronics r detached, there's no smell form the motor and the drum spind freely if I rotate it myself
  • mitgninnug
    Apologies for the spelling, I'm on a phone....
  • mitgninnug
    How would I test the timer?
  • Indesit Master
  • 1,344 Answers
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 18, 2012
  • Jason Kennidy
    Jason Kennidy Jun 18, 2012
    I see, but I still have to vear away from the motor. usually, not always but 99% of the time when a motor goes bad, as soon as you push the start button, the machine will either hum and not turn or make a loud buzzing sound which stops when the button is release.
SOURCE:
SOURCE: Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Posted on Nov 26, 2006
kjmac
  • 97 Answers
SOURCE: Indesit W123 - 8 Flashes Error Code
thats a problem with your heater, or the heater relay on the main pcb. best off replacing heater first as its the cheapest option.
hope this helps
kj
Posted on Nov 07, 2007
jason0110
  • 66 Answers
SOURCE: indesit w123
not really worth replacing timer as many problems can cause this
Posted on Jun 15, 2008
jason0110
  • 66 Answers
SOURCE: indesit w123 front load
would check pressure switch and the pipe that goes down to the drum for blockages if not may be faulty water valve unplug first regards jason
kevin000
  • 1847 Answers
SOURCE: Indesit WI 62, i believe
it seem issue with the water senser.
Posted on Jun 25, 2008
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
W123 holding some water and dial keeps spinning around checked the filter all clear
may be a blockage in the sump hose or pump feed hose or the pump itself may be faulty. the dial will click round to tell you there is a fault. to reset turn the dial onto every DOT and turn on for 10 secs then off and onto the next dot it will flash for a couple of seconds to confirm.
Mar 17, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Indesit w123 prog dial goes round but does not do anything else?
It's the motor brushes that are worn and taking down the neutral side of the circuit hence nothing else works !
May 19, 2008 | Washing Machines
hope this helps
kj
Oct 26, 2007 | Indesit W 123 Front Load Washer
Indesit w143uk
these machines are a problem! the dial clicking round can be a component fault - ie pump etc - or a module fault. from what you describe, fault could be with the pump. an easy way to check is to power the pump up independently and see if drain works ok. (i assume you have checked the filter) after that, check continuity in the heater as well. if both of these are ok, you are faced with a module fault
Jul 21, 2007 | Indesit W 123 Front Load Washer
Indesit w123 washing machine
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
May 22, 2007 | Indesit W 123 Front Load Washer
Oct 11, 2006 | Indesit W 123 Front Load Washer
Indesit Door Handle Kit for W123, W133, W143, W161, W83, W93 Washing Machines Logo
190 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
