Question about Toshiba 32AF41 32" TV
32" Toshiba 32A42, red power light blinking, tv won't come on
Hi..I have a 32" Toshiba 32A42, 32A42A, 36A42(one of these three), saturday morning when I went to turn it on, the tv didn't come on..but the red power light started
blinking off and on..I also notice a small area(approx. 3") with different colors on the middle left area. I have had the tv(bought new)for approx. 6 years. It's very heavy. Any idea what it could be? It was working great
friday and friday night, I turned it off on the tv itself, not
the remote like i usually do. Any help would be very much appreciated. Thank you.
CT90037# on remote that came with tv(if this helps).
  • Anonymous Dec 06, 2008
    I have the same problem we un plug the tv then plug it back in and it works its a pain but it works
  • buckhunter1 Jan 25, 2009
    When powering on the TV the power lights blinks. No picture on screen and TV is not working.
2 Suggested Answers
jerryg50
  • 1673 Answers
SOURCE: Toshiba 36A42 36'' T.V.
A common cause is a failure in the one of the scan amplifiers or on the high voltage section. It is also possible to have a power supply fault that will give this error message.
Jerry G.
Posted on May 15, 2009
Power light blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 16, 2014 | Toshiba 32A42 32" TV
Toshiba 32A42/32A42A. Just moved tv to bedroom, worked great for 2 days, now the picture has vertical lines. Turned it off for 15 minutes, picture came on, 10 minutes later lines appear again. Anyway to...
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Mar 09, 2014 | Toshiba 32A42 32" TV
Toshiba model 32a42
your power supply needs to be replaced , you can do it your self
Oct 09, 2013 | Televison & Video
Toshiba 32a42. power light flashing, tv will not turn on. tried unplugging for about two hours and that did nothing.
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place.......
Apr 14, 2011 | Toshiba 32A42 32" TV
TV won't turn on . Red light on front not on at all.
hi
1- unplug the AC wire
2- wait moments
3- plug the cable - if turn on lucky you. otherwise you have to bring it to repair shop
good luck
Jul 25, 2010 | Toshiba 32A42 32" TV
I have Toshiba 32A42 CRT TV that stopped working
This unit has a horizontal/high voltage issue. This is a dangerous circuit to work with so you should have a shop check it for you. Thanks for using fixya.
Nov 09, 2009 | Toshiba 32A42 32" TV
Jerry G.
Dec 14, 2008 | Toshiba 36A42 36" TV
Tv will not go on
On my GE Tv/VCR Combo I had a similar problem. Try holding down the Power button on the remote for at least 7 seconds. This disengages the parental controls. I found this solution on another website after my tv stopped working after my 20 month old played with the remote for a while. This solution was not in manual. I am assuming that he held down the power button for 7 seconds to engage the parental control. Hope this helps!
Nov 10, 2008 | GE 19TVR62 19 in. TV/VCR Combo
Kids.
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
Nov 23, 2007 | Toshiba 32A42 32" TV
Toshiba 32AF41 32" TV Logo
434 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
