Question about GE JVM1850 1000 Watts Microwave Oven
Cannot remove plastic upper exhaust fan grill for cleaning
GE JVm230 has a horizontal balck plastic louvered grill across the top, through which the fan blows. I cannot figure out how it attaches/detachs to clean it.
Is it meant to be removable? Is it a snap in connector to the frame behind it? Should I just force it off?
  • GE Master
  • 9,098 Answers
Here are the steps to take:
1. Unplug it from the outlet.
2. Remove the two screws hidden in the slats of the grille.
3. Jiggle it up and out to remove the grille.
You can download your owner's manual here.
Posted on Dec 08, 2008
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
Replace fuse on ge microwave oven model no. jvm230
remove all outer screws, take off cover, has fuse panel inside, probably ceramic style fuse ?
Jan 30, 2011 | GE Microwave Ovens
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Dec 11, 2010 | General Electric Microwave Oven
I can't remove my GE spacemaker microwave from the wall
should only be two phillips head screws in the grill holding it.tilt top out first and lift out. if the metal above is smashed down on grill the screws thru the bottom of upper cabinet need to be loosened,< not removed just loosened > and this should help. Some models slide one way or the other to release tabs also.
Apr 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave oven
ge microwave fuses are behind upper grill and behind right side grill
Jul 25, 2008 | Microwave Ovens
Getting to the circuit board
First, remove the plastic vent / louver going across the top of the unit. Once that's off, you should see one phillips screw at the top of the control panel frame. Remove that screw, then lift up and out on the control panel assembly. You're there!
Jul 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
Jul 29, 2007 | GE Advantium SCA1000H Convection /...
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here:
May 03, 2007 | GE Advantium SCA1001SS Convection /...
Buttons for light and fan
I had the same problem with the three buttons pushed in.  Here's how I fixed it:
1. turned off power at breaker or pulled plug 2. Unscrewed two screws on top of unit 3. Removed exhaust vent cover/grill by sliding it to the left and out 4. Unscrewed single screw above LCD control panel 5. Removed control panel assembly by sliding it up and out and rested it on a box so wires wouldn't pull out 6. The control board behind the three buttons had dislodged from the clips 7. Secured the control board with the clips and added a little superglue to clips and extra foam padding to keep it from moving. 8. Screwed the control panel back in, powered up, and tested 9. Reattached the exhaust vent and screwed it back in
Dec 01, 2006 | GE JVM2070 Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
206 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
