Question about Whirlpool GS6SHAXLS Side by Side Refrigerator
Magnet area is very hot
I just purchased a used GS6SHAXLS and the magnetic strip area of this refrigerator is generating heat. It is extreamly hot to the touch. Any suggestions on what the problem might be. Thanks in advance.
    President:
  • 878 Answers
Vtdeanda, usually that is a sign that the condensor fan is not running. Could be jammed with something. It sits in the back by the compressor. Check this out first..Catriver..post back
Posted on Jan 30, 2007
What is a magnetic seal on a refrigerator door?
Its strips of magnet on the parts of the door and the part of the inner frame of the fridge that hold the door sealed with magnets nice tight seal.
Sep 05, 2014 | Amana Refrigerators
How to you replace the freezer door seal
is it a latched door, if so weather stripping (high density foam) is a good alternative, commonly used on edges of doors, believe it or not that is a door seal just without the cover to make it more pleasing to look at, it comes in various depths, sizes and is normally two sides adhesive. if it is a magnet strip type; pick a side and use it as a strip magnet surface or cover it.
Oct 14, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
The center wall that runs vertically between the freezer and refrigerator compartment is very hot on the end that is exposed when you open the refrigerator door (hot enough that the magnetic strip that...
Well, that is were a heating wire runs to evaporate condensation at the seal. So it is normal that it gets slightly hot, but if really hot, then call for service
Jun 18, 2017 | KitchenAid Superba® Architect® KSRP22FSMS...
What causes the metal strip that the door magnets use to get hot.
Here is a tip that I wrote about the reasons why the sides and/or seals could be getting hot on your refrigerator.
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
Jan 28, 2011 | Amana Refrigerators
Magnetic strip that holds door closed is hot to touch and there is an elec. smell.
Is this strip hottest between the freezer door and the fridge door? If so, then you'll need to take a look compressor area (It should be located on the the bottom of your unit near the back of the fridge) I believe it may be covered by a piece of cardboard depending on the model. Take off the cover and you will see the compressor and a condenser fan. Make sure this fan is turning and blowing lots of air when the compressor is on. If it's not running, then that's most likely your cause for the hot strip. You'll need to clean the coils and fan and maybe replace the fan if it's starting to go.
Sep 22, 2009 | Samsung Refrigerators
Magnetic divider strip is hot. Temperature not cold enough
Yes this is normal. The heat strip is there to prevent moisture from forming around the the door frames. It also is most noticeable if the heat wave is causing your refrigerator to struggle to cool. Cleaning the coil below the refrigerator and making sure good air circulation in that area will help. If you have any questions please let me know and visit my siites. Please rate me if this was helpful, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Jul 30, 2009 | Whirlpool Refrigerators
Door on right opens as if the magnet is not strong enough.
clean the area where the magnetic door gasket contacts If the gasket appears warped
use your hairdryer on medium to gently heat the magnetic gasket pulling it out toward the door opening to restretch it
May 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Suzuki SE4000SED generator with no output
There was a day and time when generators were simple. There were no capacitors, regulators to control/adjust power to magnet or ground fault outlets. Winding getting hot indicates short, however could be bad capacitors. Rectifiers and capacitors must be removed from circuit to test properly. Here is a simple test that I use to find fault area. I use a small power supply (16v AC 1 amp like doorbell transformer) into the 110v outlet of generator. This should energize the armature magnet and actually produce voltage at commutator with brushes pulled off. You can slowly pull the starter rope to move the armature into a different positon the voltage will vary. If the ac windings are shorted there will be very little or no magnet. There is a seperate 110 v circuit at the 220v outlet to test (there are two 110v windings that make up the 220v outlet, one is also used for the 110v outlet). There is another winding that products voltage for the regulator that powers the magnet thru the brushes but I think that circuit is porbably working because of the heat in the windings. You might even have 110v power at the 220v outlet. As our parents told us over and over, be careful when working with electricity. Enjoy
Dec 06, 2008 | Electrical Supplies
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Open Questions:
Whirlpool GS6SHAXLS Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
