Question about LG RUMOR Cellular Phone
Want to Block my Number from Showing
How do I remove my cell number from being displayed on outgoing calls?
    Brigadier General:
  • 7,752 Answers
You will have to go into your settings and go to call ID and place it on private.
Posted on Dec 27, 2008
How do I remove numbers from call blocked
The question is a little unclear. Can you please specify. Is your call ID blocked when you make calls? If so which Service are you using?
??If you are using Bell see this site
How to block or unblock my mobile phone number when making an outgoing call
Nov 22, 2016 | Cell Phones
Tip
IPhone secret codes
<span><span> <p><span>Follow the list of latest Apple codes list: </span><br /></span><span> <p><b><span>Code Action</span></b><span> </span><br /></span><span> <p>*#06#<span> </span><span> </span><span><span> To display the IMEI Number of the mobile</span> </span><br /> <p>*225#<span> <span> </span></span><span>Use to display the balance detail of postpaid number</span><span><span> </span> </span><br /> <p>*#43# Use to verify if call waiting is enabled<br /> <p>*#61# Verify the number for unanswered calls<br /> <p>*#62# Verify the number for call forwarding if no service is available.<br /> <p> <br /> <p>*#67# Verify the number for call forwarding if phone is busy<br /> <p>*#646# <span> </span><span>Use to display the minute detail of postpaid number</span><span></span><br /> <p>*777# <span> Use to display the balance detail of prepaid number</span><span> </span> <br /></span><span> <p>*3001#12345#* Display the iphone inner settings<br /> <p>*#33# To verify whether barring is enabled or disabled for outgoing<br /> <p>*#21# <span>To display the </span>settings for your call forwarding<br /></span></span>
on Dec 02, 2010 | Cell Phones
How do I get my name to show up on recipient's screen. Showing as restricted number.
you would need to block you number some how befor you call
or
acsess the recipients phone and change you contact name to restricted number save when you call(restricted number) will be displayed
Oct 03, 2015 | Cell Phones
How do I ge my number to be displayed on my outgoing calls
In order for your number to appear on telephone Caller ID (CID) display screens, the person you're calling must subscribe to CID service AND you must have a published phone number (that isn't being "blocked"). Some phone companies allow published numbers to be selectively blocked on a per call basis or on all calls until the block is removed.
If your information is being broadcast incorrectly or not at all, you should contact your phone service provider.
Nov 21, 2014 | GE Lands Phones
How to hide my phone number when dialling or receiving calls
Dial *67 from the united states to block your number on outgoing calls. For example, if you wanted to block your number before calling 111-222-1212, you would dial *671112221212.
If someone is calling you then... they already have your number. Nothing you can do about that :)
Mar 07, 2011 | Cell Phones
How do i block my number on an outgoing phone call?
i found the answer at http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Jan 07, 2011 | HTC Snap S522 Cell Phone
How can I block my number from showing when placing a call? My tel number is stored under Contacts/My numbers. I want to remove the number so it does not show when I am placing an outside call.
from menu,go to settings on your phone>call settings>send caller identity, press on your send caller identity, you will off option, select and save. you number is now hidden when making out going calls.
Take care.
May 17, 2010 | Nokia 3320 Cellular Phone
Ristriction password Nokia E71
if you mean that you are trying to place outgoing calls where you don't want the call recipient to be able to see your number the way to do that is to dial #31# and then the number you are calling for example:
#31#310-222-3333 (the recipient will see "blocked number" instead of your number)
Aug 28, 2009 | Nokia E71 Smartphone
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
Jun 30, 2008 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
LG RUMOR Cellular Phone Logo
300 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
