Question about Lite On Televison & Video
I just bought an external 20x Lightscribe SuperAllWrite DVD recorder. It writes DVD's all the way sometimes and most of the time it writes the DVD part way then gets an error. Writing the lightscribe label works part way sometimes and most of the time not at all. The Nero 7 essentials won't install. I'm using a netbook Acer Aspire One.
  • 11 more comments
  • SnowDog98 Dec 02, 2008
    20x combo drive.
    Tested on another computer with Windows XP and it still didn't work. Read discs fine on both PC's.
    The
    My internal lightscribe works fine on my other computer with the same software.
  • SnowDog98 Dec 03, 2008
    You keep sending me the same solution. I told you I tried what you said and it didn't work.
    Tried recommendation. Still didn't work. Sent an e:mail to liteonit.com. Maybe they will help me since it is a liteon product.
    Could the dvd writer be too fast for the 16x dvd's that I'm using?
    I'm using dvd+r dvds.
    I've never seen the power save suggestion until now. It makes a lot a sense. I will try it and let you know.
    I shut down all the power save modes in everything I could find and it still doesn't work. It will go part way thru and shut down when writing disks and lightscribe burning. That's why the power save mode made sense. It was like the hard disk was shutting down before it could finish the operation. Can you give me any other suggestions or are we done.
    I've tried everything suggested. Nothing worked.
    I nvever got Nero-7 installed; never used it. Wouldn't burn dvd. Wouldn't label with LightScribe. Burns both part way then stops.
  • SnowDog98 Dec 04, 2008
    None of your suggestions have worked so far. Any more suggestions? The internal dvd drive in the desktop pc burns fine and burns the lightscribe image fine every time I use it. Hardware is useless if you can't depend on it everytime. The external liteon drive reads fine both doesn't finish writing a dvd or burning a lightscribe image on my netbook. The extenal drive also didn't work when I tried it on the above mentioned desktop Pc.
    Sergeant:
    Champion:
  • 331 Answers
 The DVD stops writing halfway....
did you try writting on the DVD small file and see if they are written properly... If they are then there is no problem with your installation and also  no problem with the software you are using.
the only problem with the external drive might be the interfacing  unit as someone mentioned  the unit is either getting heated up. vary quickly or the interface is not secure enough to manage the motion of the  DVD (it is spinning inside at a fast rate and so the unit is vibrating)
so eitherway you will hae to open up your unit and see inside.
pls post back  about the first part (small files are being written or not)
Posted on Dec 04, 2008
  • 728 Answers
Since you say you are using dvd-r dvd's, try use dvd-rw dvd's and try burning to see if it works because you might need a re-write-able dvd instead of a recordable dvd to work with the burner.
Since you say that the lightscribe labeler on works sometimes, try un-installing any software and re-installing it and see if it works then.
Posted on Dec 03, 2008
    President:
  • 2,110 Answers
Youfirst try to clean the lens by a lens cleaner...if not worked then there might be some problem in lens & replace the lens...
    Genius:
  • 3,422 Answers
The problem is with your Nero-7, please uninstall it and go back to Nero-6, your problems will be solved.
With version 6 you can burn dvds and play and have a Firefox open with a few tabs. I could never do that with version 7.
Good luck
    Master:
  • 763 Answers
Sir, you've tried it all and seems nothing happens then try BURNING without any programs opened (close all unnecessary aside from NERO while burning let me know what will happen.
thank you for using fixya
CHARCOIS
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The favorable action would be seek warranty replacement being new. If for some reason, warranty would not be availed, then it would be suggested that the traverse guide pin where the lens carriage move along be cleaned and re-lubricated. It would not be a lens read error. But of course, this would mean that the unit has to be opened up.
As to the Nero installation, try re-installing with the anitvirus and anti-malware temporarily disabled.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 02, 2008
  • Lite On Master
  • 19,396 Answers
You have more than one problem in there.
Test the DVD on a different computer, one with a good Windows OS installation. IF the unit works fine, as I think, it means that the only troubles are with Windows.
You can try a system restore or using software like the norton, if you have norton utilities, but to fix this kind of problems is often necessary to reinstall windows.
System Restore on Windows...
  • Ginko
    Ginko Dec 03, 2008
    If the DVD is new, it read correctly, and does not write, this is because of the unit limitations and for the type of media used.
    If this is the Lite -on , the unit supports the following formats (or is supposed to ):
    20x DVD±R Burn, 16x DVD±R Read, 8x DVD+RW, 6x DVD-RW, 8x DVD±R DL, 12x DVD-RAM, 48x24x CD-R/RW, Black, SATA
    This DVD is supposed to read both +R and -R, however, being a DVD -R -RW, and not a real double layer , it will always have trouble with DVD +, particularly if they are not good brand ones.
    Try using DVD-R if you want to keep this unit.
    If the unit is not new, use a Dvd Lens Cleaner , this will increase reading /writing capabilities by cleaning the lens.
    If this does not help you may consider to get a replacement with a different model.
    This unit is not faulty, and the problems in writing DVD are caused by:
    Unit limitation/Support used.
    Windows and the PC used is slow and has problem (if it did not install Nero, Windows is bad).
    Solutions:
    To fix Windows you can only reinstall it.
    On the DVDs used, Get good brand -R DVD s and try .
    Your 20x Superallwrite ... is already outdated.
    If I was in your shoues I would return the unit and buy a double layer model, like this ones (chose ones with dual layer).
  • Ginko
    Ginko Dec 03, 2008
    You did not try everything Try DVD -R and contact the sellerto replace the model with a dual layer.
    You did not do any of the above,
    I report my last comment that costed me 15 minutes of my time, wasted on this problem:
    This
    Solutions:
  • 837 Answers
Is the recorder a + or - drive or is it a combo +/- drive? Be sure your media matches and I find that even in combo drives that + media seems to work better
  • 6 more comments
  • Jay Glendenning
    Jay Glendenning Dec 02, 2008
    Have you ever "played" a dvd in this drive?
  • Jay Glendenning
    This is a USB interface device correct?
  • Jay Glendenning
    Make sure that the laptop(s) are not going into power saving mode, even if plugged in. Possibly change the power features to desktop and set all saving features (even screen) saver to none and see what happens then.
  • Jay Glendenning
    Jay Glendenning Dec 03, 2008
    So you are telling me you tried the power saving feature changes as I sent you before ?
    then.
  • Jay Glendenning
    In this post and the previous post you did not tell us the error .. what is it?
    Have you tried doing a system restore to a date prior to the initial install of this new burner?
  • Jay Glendenning
    I would suggest that you try to get 8x dvd+r recordables .. I have always had much more luck with slower speed media
  • Jay Glendenning
    Did I misunderstand but did you say @ one point you had it work on a computer?
    Try setting the recording speed to the slowest it will allow.
  • Jay Glendenning
    Jay Glendenning Dec 04, 2008
    SnowDog98,
    Have you resolved this?
  • 495 Answers
May be the DVD on which you are writing has damaged. For Nero 7 please provide the version number
  • Manoj Rout
    Manoj Rout Dec 02, 2008
    Install the latest Nero 7 software:
    http://www.nero.com/enu/downloads-nero7-...
My dvd not writing but read
There can be several reasons for that. Try to use Nero software if you are using LG SUITE. Also the DVD write speed and format has to match that of your writer. Ate you copying another DVD or writing data or edited media such as movie video or music files? Check compliance format.
Jul 11, 2013 | LG SecurDisc 20x Internal Double-Layer DVD...
Im having trouble with my drives it wont read the cd or burn the cd or dvd
Hello there,
If your LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe does not read disc, burn cds or dvd, then it means there is a problem with the lens of the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe.
You will have to replace the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe or have the lens replaced.
Be sure not to use the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe to watch movies as that weakens the lens easily.
Hope this helped.
Goodluck
Elect_Comp
Aug 09, 2011 | LG SecurDisc 20x Internal Double-Layer DVD...
A freind let me borrow their hp dvd 1040e external 20x multiformat dvd writer. i can burn the music on cds fine with itunes, but i cant figure out how to use the litescribe to burn images on the tops....
You will need Nero burning software. It will after the normal burn show you a screen where you place the image you want to burn for lightscribe. Another failing with lightscribe is that you must have lightscribe discs!
Jul 09, 2011 | HP DVD1040i 20x Super Multiformat Dvd...
Anyone know where to get the drivers for my LG lightscribe burner GSA-E30L ?
Windows XP/Vista/7 operating systems have the driver for all disc drives build in. If it isn't working, then the driver is not your problem.
Mar 23, 2011 | LG GSA-E60L 20x DVD?±RW USB 2.0 External...
Can i write double layer dvd on my lg super multi dvd writer (GH22NP20)
The drive's name tells us that you can write a double layer DVD just fine. Have you tried it ou yet? please update me of the proceedings so I can be of better help.
Dec 07, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    HP DVD 1040 external lightscribe
    1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
    2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
    3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
      double-click on Lightscribe Service, and if it says disabled change it to automatic, then "start service" in the left pane if is already started and set to automatic stop and restart it you don't have to reboot to see results.
    It worked for me on HP6710b with internal drive and with liteon external burner
    Dec 16, 2008 | HP DVD1040e DVD-RAM Burner
    System cannot see lightscribe drive
    try to update the firmware of that drive. then try to go to device manager to see if there are any changes.
    Mar 23, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
    Wont recognize a blanck dvd rom
    Try downloading the latest drivers and firmware
    Feb 05, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
    Dvd writer for toshiba satellite pro
    HP dvd1040i 20x Super Multiformat DVD Writer
    Price: $69.99
      Internal drive (double layer)
     Write speed: 8x double layer, 20x DVD±R, 48x CD-R
    Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
    Read speed: 16x DVD-ROM; 48x CD-ROM
    Lightscribe disc-labeling technology
    one-year limited warranty....
    HP dvd1040e 20x Super Multi DVD Writer
    External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Televison & Video Logo
    22 people viewed this question
    Top Lite On Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
