Question about Sony RDR-HX715 DVD Recorder
Crashes often-goes to recovery-works again
This happens in play and in record it sometimes records correctly, sometimes half a show, sometimes won't even start to record, Use wise this recorder is almost new since I quickly replaced it with panasonics and others when it started acting up but as they wear out and can't be replaced anymore I'd love to be able to start using this Sony again, my favorite for picture quality. Thanks for your help!
  • 10,594 Answers
Let me know....
If it repeat operation (crashes) after WELCOME is displayed?
Or it shows Disc Error on display when used DVD+RW
Posted on Dec 02, 2008
  • 837 Answers
Try to get 8x speed or less media .. these machines seem to have problems with "faster" discs
  • Sony Master
  • 19,396 Answers
If it crashes and restart is either a firmware problem or an hardware fault.
If it freezes in the middle of the playing it can be a drty lens problem.
If it turns power off completely, then it is probably a faulty power unit.
  • Ginko
    Ginko Dec 02, 2008
    The fact that has problems in playing and recording let me think that there can also be a dirty lens problem.
    Try using a good dvd cleaner, possibly a good one with cleaning solution, like the ones on this list.
    If the unit is restarting itself there may also be a firmware problem. The model is not on Sony website. Contact them on live chat, using the button at the left of this page to know what to do if the lens cleaner does not work.
  • Ginko
    Ginko Dec 02, 2008
    More precisely, as pointed out,
    If it repeat operation (crashes) after WELCOME is displayed, it is likely a firmware problem or a fault. Better to contact Sony , see Contact Live chat button on this page.
    If it shows Disc Error on display when you record or play, or -- or 00 or freezes very often while playing and recording, it is probably the lens. Try lens cleaner first.
    If that does not work, next step should be isopropyl alcohol and cotton to clean the lens, but for that you need to take apart the unit.
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
Hi, All Folders are locked and if you try to record its says READ ONLY CARD? I have 1 sound file on the card which i need. It won't play on the computer system either?
The memory has been corrupted. You will need to reformat the memory from the menu in order to use that memory card again. This will erase all files.
If you need to recover the file, download a free recovery program called pc inspector smart recovery, from http://www.snapfiles.com/get/smartrecovery.html
Jun 23, 2011 | Olympus DS-2300 Digital Voice Recorder
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
My dvr shows a 1hr program fully recorded, and begins playback fine. After almost 10 min playback ends but when paused, continues to show another 50 min available.
Hello! Daniel Busa with Dish Network here. That actually happened to me about a month ago a hard reset resolved it for me. If that doesn't do it try deleting all of the recordings that don't play back correctly,reset it again and keep an eye on things, it may be a bad box.
Nov 10, 2010 | DISH Network ViP722 DTV Receiver /...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Player shutdown and then go to self check
unit goes in to self checking over and over dvd can not be ejected and will not function at all?
Aug 05, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-EH55 DVD Recorder
i have panasonic DMR-eh55 dvd and for the first time when i played that it was in japanies language thus i tried to convert the language in to english through remote control i selected one by one thus suddenly there came a message U302 and now when i play my dvd and as i press remote control it show on dvd screen U302. please how my remote will work again and how can i get the solution so that my remote control works....
Nov 11, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
59 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
