Question about Broderbund PrintMaster Platinum
Want to be able to open my projects in photoshop
I would like to know how I can save my projects in a way that it could be open by another program like in jpeg or another popular format and I would like to be able to save them on another hard drive of my computer.
thanks
    Problem Solver:
Under File, choose Export As...Use the drop-down box for the desired extension (i.e., jpeg). You can also choose to what drive and folder you want it to be saved. Good luck!
Posted on Apr 04, 2009
  • 102 Answers
Just do a "save as" and select the format you want that will open in another program. you can select your hard drive then as well
Posted on Dec 03, 2008
Is There Anyway Of Retrieving Unsaved Photoshop Work?
f you have CS6 or later, Photoshop has a Preference that saves recovery information every 10 minutes (but it can be set to 5/15/30/60 min as well).
If Photoshop crashes, and IF it has saved recovery information about the open document(s), it will try to automatically recover them (they will simply open automatically when you start Ps).
If they do not open when you start Photoshop, tough luck, they are lost. :(
But to me it sounds like you haven't quit Photoshop yet? If so I would dig around a bit more before force quitting to make sure there isn't just some dialog box you need to click hidden behind the main window, on another monitor, or something...
may try third-party PSD file repair tools by searching Photoshop Restore Toolbox http://www.photoshop.restoretools.com/
Aug 25, 2015 | Adobe Photoshop 7.0 for PC
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
I can't open Microsoft Picture It! Publishing, using Windows 7. Can you suggest how?
Unfortunately, Microsoft themselves list the program as incompatible with Windows 7. In fact, the entire Picture It! product has been discontinued. This means that there won't be any updates or later versions to make it compatible. You'll need to find some other software to take its place.
One good free program for image viewing and editing is IrfanView. It's no Photoshop, but offers the basic tools most people need. It's compatible with W7, and it's free (yes I'm repeating myself but it's a good point). Here's a review from one site if you want to know more.
Mar 27, 2010 | Microsoft Picture It! Publishing Platinum...
Can I set a default program to use for scanning? When I press the "scan" button, I'd like the document I'm scanning to open in Photoshop. Right now, the button doesn't do anything. Thanks!
whatever format it saves the scan in say jpg r click on photoshop and say open with to any jpg on the desktop. There is a tick box that says ALWAYS use this program to open these types of files. Tick the box. It may be a TIFF, gif or another format but the principle is the same
If you need more help with this please get back to me
Please rate our help++++Thanks for using FIXYA
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
All my images in photoship have turned to quicktime and I cannot save back to photoshop. I have gone into tools - open as - but that only opens the images in photoshop it does not help to save them back to...
In order to change what program opens a certain file type in Windows XP, you must change the file association. To change the file association for a specific file, you first need to view the file's properties.
You can view a file's properties by simply right-clicking on the file and selecting "Properties" from the contextual menu that pops up.
Now, in the properties window, you will see a line saying "Opens with:" and next to it the program that opens your file.
To change this file association, click the "Change..." button.
A new window ("Open with") will open where you will choose which program you want to open your file. For example, to open your image file, choose photoshop. If you can't find it on the list, click on "Browse" and search for Photoshop.exe (probably in your Program Files).
If you want Photoshop to open all files with the same extension (e.g. all .jpg files), you should tick the box at the bottom of the "Open with" window saying "Always use the selected program to open this kind of file."
Hope this helps.
Sep 15, 2009 | Adobe Photoshop CS for PC
Lost data on Hallmark card studio save program
I really can't say how I solved my problem, because I'm not sure what I did to make it go away. Thank you for responding.
Aug 27, 2008 | Adobe Photoshop 7.0 for PC
CS3 locking up when I am trying to "save as"
you also can try to restore preferences files.
click shift+ctrl+alt when open any cs suites and click yes when you are prompted to restore all preferences.better try this before you taking hard times of reinstalling it.
saralunaxp.wordpress.com
May 12, 2008 | Adobe Computers & Internet
Can't save my psd file
search and destroy / modify the file 'editing.xml' in your 'application data' directory.
it will be in your %temp%\..\..\Application Data\Adobe\Workflow
(if ur operating is win 2000 / xp)
have a nice day
bye
Jan 15, 2008 | Adobe Photoshop 7.0 (321115627)
Photoshop 7 invalid image file
If you have Ifranview open it in Ifranview,and
save it as a jpg or save it as a gif in Photoshop
whatever you did to the image thats invalid for
jpg you can save as gif
Oct 29, 2007 | Adobe Photoshop 7.0 (321115627)
Broderbund PrintMaster Platinum Logo
96 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
