Question about Frigidaire Heating & Cooling
I have a frigidare gas heating unit aprox 8 yrs old. the problem is the unit comes on the ignitor heats up gas comes on and lights but the gas only stays on about 5 seconds then shuts off?
  • James Sledge
    James Sledge Dec 02, 2008
    thanks skeeter140 trying your solution so far so good! have a Merry Christmas!
  • 306 Answers
You have a flame proving device that senses the flame. It is located on the last burner in line looks like a piece of thick wire. Take some steel wool and gently rub the outer surface 4 or 5 strokes is all it takes to remove the carbon that has built up. Let me know how it turns out. Ken
Posted on Dec 02, 2008
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
GGW9200LW0 whirlpol dryer runs but ther is no heat. It is 8 yrs, old. Waht to do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Whirlpool GGQ8831L Gas Dryer
Slow to heat up
Most likely your ignitor is going bad. This is the part that glows before the gas comes on. It has to draw the proper amperage to allow the gas in the oven to light and burn. Some ignitors glow and look good but are not drawing enough amperage for the gas valve to open, with the problem you are describing.
Very fragile part, easy to break,
good luck.....
Feb 24, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
if gas check the ignitor,thermal fuse, and secondary gas coils,
Feb 05, 2010 | Maytag Dryers
Kitchenaid gas oven very slow to start - can be 5 - 10 minutes before I hear it kick on. For a while I could get it to start by turning on a gas burner, but that is 100% effective. Any suggestions? Also...
Replace your ignitor, this is a very common problem. As the ignitor gets older, it gets weaker. When it gets weaker, it usually starts out by not giving good temps in the oven, then it starts to take longer and longer before it lights the oven burner, then it stops lighting the burner completely. A good ignitor heats up fast, allows the current to flow through to the gas valve, opens the gas valve and lights the oven burner within 30 to 50 seconds. When you order your ignitor ask if their is a cheaper generic ignitor for this model. Their can be a huge price difference in some units. You can also have a bad sensor, control board, gas valve, or wiring problem, however for the last 15 or so years every job I have done with your problem has been an ignitor. Good Luck, Appliance Specialists
Jan 26, 2010 | KitchenAid KESC307 Electric Kitchen Range
Bottom burner does not light, broiler works
Looks like you'd want a 74007498 oven igniter, which generally goes for about $75. Personally, I'd fix it, but the final call is your, or course. Please don't bother rating, as anything but a Fix-Ya lowers my score. Thanks.
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Oven problem.
Only 81/2!! most are only expected to give you 5 good yrs anything else is extras. Your problem may be a defective gas valve (safety valve). Also it may be a defective ignitor - the more likely to go bad (if replacing stuff replace ignitor before safety valve. is there a glowing in the oven? does the flames come on any at all?
Post a response
Regards
Sep 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
79 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
