Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hot point aquarius wf740
My washing machine won,t work there is a error code f 03 flashing can you help thanks
  • Hotpoint Master
  • 3,463 Answers
Hi.
F03 indicates that the wash thermistor is open or short circuit.
I think you need to call engineer to sort the problem
Please leave feedback.
Posted on Dec 02, 2008
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD640 Front Load...
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have an aquarius plus, wf740. i bought in 2005. the problem , i have today is; it will not drain out.and it is displaying a code FL-05. can you help, cf
I have just fixed my washing machine with the same fault. As yours, my machine would not drain though it would wash, i changed the pump and it was exactly the same. Eventually, after much hair tearing out I took the Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} pipe exiting from the drum off and found a hankie blocking the pipe, job done!!!
Apr 13, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washing machine wf740
Error F01 is indicating that the motor triac has short circuited, this is part of the electronic speed control for the motor.
Hotpoint's advice is to call an engineer, and I would concur with this, it is not really a DIY repair, unless you have a good knowledge of electronics.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Jun 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
223 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
