Question about Sony Mavica MVC-FD200 Digital Camera
Error C 13 01
Have new memory stic for camera but when inserted the display shows memory stick error even after i formatted the stick. can you help me?
  • ismg Jan 09, 2009
    purchased a new memory stick and get error code c13:01. can any one help
  • Homer Mudd
    Homer Mudd Feb 22, 2009
    LENS ON SONY DSC-W30 WILL NOT OPEN
  • 849 Answers
May be it is not compatible with camera.
Posted on Dec 02, 2008
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
Jan 01, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
INSERT ANY NEW MEMORY STICK SHOWING FORMAT ERROR
Please format memory stick by camera Menu >> Format option.
If problem still exist, try another memory stick and check camera again.
Apr 25, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
My sony dsc-s650 does not work, ichanged out battery, memory stic
memory stick corrupt try formatting it on pc laptop card reader then try it
Feb 17, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Memory stic in camera format problem
dear,i've sony cybershot DSC_W35.I was getting format error c13.01 when i insert sony memory stick.but I've no problem when i was using internal memory.how can you rectify this problem
Nov 07, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Memory Stick Error
Go to camera menu and Format memory stick then try.
Sep 06, 2008 | Sony Handycam DCR-TRV340 Digital Camcorder
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Mavica MVC-FD200 Digital Camera Logo
370 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
