Question about Lexmark E238 Laser Printer
Paused Position How do I remove this paused position
  • 849 Answers
Click resume in the printer's property
Posted on Dec 02, 2008
Super general SGW8100(S), what is meaning of error code E61?
think its Insufficient heating (maximum time exceeded).
Possible fault Heater unit faulty; Wiring faulty; NTC sensor incorrectly calibrated/out of position; Electronic board faulty.
Machine Status/Action Cycle paused.
Dec 16, 2016 | General Dryers
Second hand not moving
If the Chronograph is running, the second hand may be paused as on of your dials is recording seconds instead of the larger second hand. You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 | Watches
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
Printout not align and faults indicates led lit up
The Media Sensor is not seeing the labels or is not configured for these labels. Check Media Sensor position and settings. The Fixed Sensor models have a small window for the sensor at the bottom of the printer, about 3/8" to the right of the left side. If the printer has a movable sensor, the typical position is either 1" to the right of the left edge of the labels, or in the center of the labels. Typical media sensor setting is "Gap Mode". Another common issue is that the sensor might have a piece of label or something stuck to it, covering the lens. Finally, there is a possibility that the reflectivity threshold may need to be recalibrated (see below). This can be difficult, although there are instructions in the Operator's Manual. If physical position/clear view of labels by sensor doesn't seem to be the issue, an easier way to deal with settings issues might be to Restore to Factory Defaults (see below).
Datamax E-Class Auto Media Calibration Procedure:
The 'Auto Media Calibration Procedure' allows the operator to
automatically obtain the optimum (TOF Low and TOF Delta) values for
a particular media. These values are useful for media that continues to
have troubles after Media Sensor has been manually calibrated (usually
preprinted media). This operation feeds 10 inches of media using the
current Media Sensor Calibration setting and calculates the TOF Delta
and TOF Low values to be used. Upon completion the printer will exit
back to 'Calibration Mode' flashing the PAUSED light if successful or
the FAULT light if not successful.
Note: Before calibrating, be sure the media sensor is set for the
appropriate media type, see section 4.4.2, also be sure the
printhead is latched down and the cover is closed.
To perform the Auto Media Calibration complete the following steps:
1. Load the desired media.
2. Hold the button while powering up the printer. Continue to hold
the button until the PAUSED light turns off then release.
3. Next press the button, (the printer will now calibrate to the
media)
4. The PAUSED light will flash 5 times to indicate a successful
calibration. The FAULT light will flash 3 times to indicate an
unsuccessful calibration.
Note: If you wish to discard your changes and revert back to the
previous calibration simply turn off the printer before Step 5.
5. Now you can save your changes and resume by again
pressing the + buttons simultaneously.
Datamax E-Class Reset to Factory Defaults Procedure:
With the printer off, press and hold the F1, F2, and F3 buttons while
turning the printer on. Continue to hold the buttons down until the
PAUSED light turns off. The printer will now be set to the 'Factory
Defaults'.
Jul 22, 2014 | Datamax DMX E4203 Printer
Hi, I have a Zebra 140xi2 printer. When I print, everything is shifted to the left. I checked the PRINT WIDTH (set at 127 4/8 MM), and the LEFT POSITION (set at 0000) in the printer configuration. Is there...
turn off printer and press "pause" button + "power on" at same time, keep pressing "pause" button for 5 secs. it will star printing a
'pouse test" ike a barrcode. After 3-4 labels, just paused the job otherwise it will never stop printing untill u swicth off again.
if printing halp printer, tried to reser printer to factory default and try again. if still printing half, the printhard its faulty.
Mar 17, 2014 | Zebra Office Equipment & Supplies
Zanussi aquacycle 1200
Turn the machine to the off position. Unplug it and then plug it back in. Now try to restart the cycle. If this does not help find a local washer and dryer repair shop
Jan 24, 2014 | Washing Machines
E1081 charging paused battery durability
Charging paused battery durabitity
Apr 09, 2013 | Cell Phones
Hi I have an audi A4 '99 model the wipers were getting stuck on the intermittent but worked fine on the fastest setting although they didnt re-dock in the correct position when turned off, now they have...
Any luck with this?? I just bought a 99 avant quattro myself and when I use the wipers they don't re-dock.. Intermittent setting stop in the up right position when they are paused ..
Jan 09, 2011 | 2001 Audi A4
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
Blinking Resume Light
i think the problem is that the printer could not initialized the printer head position. you can open the cover and turn on the printer. check if the motor for feeding paper moves but the roller does not. replace the gear attached to the roller. i hope this will help.
Jul 24, 2008 | HP DeskJet 612c InkJet Printer
Lexmark E238 Laser Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
