Question about Samsung 150N Black - 15" LCD Monitor
NO DISPLAY POWER LIGHT ON
NEED TRANSISTOR PART NUMBER FOR SAMAUNG 150N MONITOR . Q201 AND Q202 THE PART NUMBER READS R04 AND R54 DO NOT KNOW WHAT
  • 849 Answers
Read the color code on it it will give u the exact value.
Posted on Dec 02, 2008
Nec lcd2080uxi, monitor power light comes on green but no video is being displayed, screen stays blank , cannot get into the built in setup selections. nothing is being displayed on the screen
Power supply or backlight inverter problems, those are the two areas you need to check.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | NEC LCD2080UXi Monitor
Wont display anything, green light on power button keeps flashing
The flashing light on the Dell E173 series indicates a failure in the power supply board. This series has several versions on the board so you will need to know the exact model, it is listed on the label at the bottom of the back cover. The versions are E173FPc, E173FPb and E173FPf. We have repair instructions posted on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ that cover each version on the unit. The repairs will require replacing a few pars that will need to be soldered.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
Dell E173fp monitor went black and green LED light on power button is blinking. It will not reset.
hughiii, Read page 16 of my fixya profile. There is a response to another E173FP you should read and then do more reading about other brands of monitors with same symptom. Will you be doing the tear-down and inspecting the power supply? After you have done the research (reading) and seen some videos on YOUTUBE, get back here on fixya and let us know what you have decided to do. 12fixlouie
Apr 02, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
E193FPC : Monitor power light on, Monitor starts up and displays image for 1 second or less, goes black and stays black, If turned off and back on it will again display image and revert to black. Results...
here is a similar dell monitor with the exact same problem....
http://www.motherboardpoint.com/dell-e172fpb-monitor-t55620.html
read all the way to the bottom of the thread and you will find:
volto user_offline.gif Junior Member Join Date: Oct 2007 Posts: 1
10-30-2007, 07:54 PM I have the same monitor and it had the same problem, I got it for $10 at a garage sale because they "didnt know if it worked or not" BS, they knew it was broke. But i accepted the challenge. There are four transistors on the power supply board detailed as Q759, Q760, Q739 and Q740. It is usually just two that go bad on these monitors, but instead of hassling with testing all four, I would recommend just replacing all four. Here are some replacement part numbers. I used NTE2524, same as NTE2525, and paid about $1.25 each.
and here are Sanyo parts (hard to obtain):
2sc5707 C5707
2sd1803
2sd1804
ECG2524
The transistors are rated at 60v 20w.
Just wanted to share my success story. Hope this info helps someone. I found my info on some other forums that i can't find right now.
Nov 06, 2009 | Dell E193FPC 19" TFT LCD Flat Panel...
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Display
Problem is with invertor board.You need to open the monitor and check Invertor transistors 2sc5707.Test all 4 transistors and replace defective,also check /resolder associated circuitry.Also check fuse with PFxxx circuit reference no.
Samir
May 11, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Feb 16, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
BC 200 XLT
It is Q201 on the front micom board.
Read about it here or search google for the word Q201 and BC200xlt
http://www.repairfaq.org/REPAIR/F_BC_Repair.html
Any surface mount pnp transistor will work. Q202 may have a B6 on the top of it.
I had to change it on mine.
Harold
Jan 10, 2008 | Uniden BC72XLT Handheld Scanner
Dell E172FPb 17" LCD Monitor Problem
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Oct 27, 2007 | Dell E153FP 15" LCD Monitor
Samsung 150N Black - 15" LCD Monitor Logo
96 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
