Motorcycles Logo
Anonymous Posted on Jun 17, 2012
Honing oil smell on skin
Hi i work with a smelly honing oil it gets into my pores and and even after a shower i can smell it especialy on my arms and when i go out in the sun it gets realy bad i was wondering if theres any soap or skin cleaner to get rid of the smell please help
Befixed
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 22 Answers
  • Posted on Jun 17, 2012
Befixed
Contributor
Level 1:
New Friend:
Night Owl:
Answers
22
Questions
Helped
20149
Points
31
I've heard that warm tommato paste will get rid of almost any bad smell. At least give it a try. It's best to wear a synthetic glove when working with solvents and oils. If it tends to get on the for-arms you can get extra long gloves that will go nearly to the elbow. Otherwise you could use plastic wrap secured with tape over long shirt sleaves.
  • Anonymous Jun 17, 2012
    thanks for the quick reply ill definitely give it a try noting to lose hopefuly a change in jobs is coming soon wont have to worry about it anymore
2answers
Where is the temperature sensor located on a 2001 Lincoln LS V8 3.9 liter
Make a day-to-day skin Vskin Active care routine and stick to it. Avoid soaps and employ a good face wash instead. After cleaning facial area don't forget to apply toner last of
http://megacleanseradvice.com/vskin-active/ Vskin Active Take Off Your Older Skin In No Time
3answers
After Im done shaving with my electric shaver, do I need to use any lotion?
In order to properly care your skin, you should use a pre-shave lotion after you done shaving. First you should rinse your face with warm water then cool water. Then, you need to par your face dry and apply an after shave balm to smooth your skin.
Honing oil smell
Yes, a thin slice of lemon, rubbed on your hands. I presume the acid in the lemon is the active ingredient, so maybe other acids (vinegar, etc) might also work.
But the question you should really be asking yourself is "how do I get lemon smell off my hands?" To that I cannot answer you, but I suspect honing oil might work.
What is the seal problem? This item discontinued about 10years ago......still good or rancid oil?
It depends on whether or not the seal is airtight, and whether or not it's been in sunlight. The best thing to do is sniff it. If it smells bad, it IS bad. Even if it smells okay, you'll still need to do a skin test to make sure other ingredients haven't gone wonky. Dab some on the inside of your upper arm (your skin is relatively thin and sensitive there-- if it's okay there, it should be okay elsewhere) and wait 24 hours.
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
