Hi my name is shaun and i am having a problem installing imperium glactica 1 it keeps sayin somethink about ms dos 5.0 do i need it as i have got windows xp if so where would i be able to get it
    Problem Solver:
  • 8 Answers
Hello Shaun.
Well this isnt my subject but im going to throw a link your way which should help you out with the whole Microsoft Data Operating System (MS-DOS) issue.
http://support.microsoft.com/kb/102901
Good luck ;)
Carl
Posted on Dec 02, 2008
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps you
Oct 19, 2011 | Computers & Internet
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
I cannot run my ms-dos file batch when i double click it appear a note pad how can i execute it to run
first make sure the extension for that batch file name is for example:
mybatchfile.bat
The name has to have the bat extension. The type of file has to be a batch file with that extension of BAT
Then at that point you should be able to run it buy double-clicking it
Jan 06, 2010 | Medion MD 96340 Laptop
Make MS-DOS Boot CD
Hi. This adress (http://www.bootdisks.us/ms-dos/5/ms-dos-bootable-cd-images.html) contains a couple of ready boot discs. Just download them (.iso file) and burn them to a CD. Hope this helps.
May 22, 2009 | Microsoft MS Windows XP Professional SP2
MS_DOS
try this type ----> cd mydocu~1 and my document will be open.
Dec 20, 2008 | Microsoft Windows XP Professional
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
