Question about Dell 5100cn Laser Printer
5100CN ask to load paper in tray when tray is full
Apparently the issue is with the Auto tray selection in Printing Preferences. I set the tray to tray 1 and it works fine. Set it to auto and then I can print only one page and then it quits
There should be a plastic flag that hangs down into the tray. When the tray is full the other end of the flag moves out of the path of an inferred sensor. Locate the sensor and try cleaning it.
Posted on Dec 11, 2008
Can i disable try 1 on this printer
Usually the paper source is set to Auto in Printing Preferences so if you put paper in manual tray it will feed from manual tray and will override the tray 1 selection. If you specifically want to change it to a tray disabling tray 1 you can do so if you go into Control Panel, Printer and right click on the printer and select Printing Preferences and then on Paper menu change the paper source.
Feb 10, 2011 | HP LaserJet 1320 Printer
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Apr 29, 2008 | Dell 5100cn Laser Printer
At school there is a printer the Dell 5100cn laser printer and we need to print labels and each time we try it asks on the computer if I want to continue because they are outside of the standard margins,...
A5 is a European paper size standard. Your label making program is telling the printer that the program needs that size label paper. You have to tell the printer to use that size paper. It may be somewhere in the menu of the printer driver on the computer or it may be on the display window on the printer, or it may be as simple as flipping a tab in the paper tray. As far as the printing outside the standard margins, most printers will allow a certain amount of that without a problem. Just tell it yes or Ok. If you solve the paper size problem and it hangs up when you tell it to print outside the margins, then the printer is not compatible with that label format in the label printing program. You will have to choose a different format. I recommend that you select a label format that is a US standard like 3 across on 8 1/2 x 11 paper.
Nov 19, 2010 | Dell 5100cn Laser Printer
In tally HP laser jet 1020 is not accepting the paper size changes. though Paper type is changed from A4 to legal
just a point of interest have you tried this and have you set the size let it take, turn off for like 12 seconds and turn back on. to me its the same as with windows rebooting after any software change, they may not tell you but i always shut it off then back on to save any kind of setting or program, it may be a wasted step but i do it anyway.
the default paper settings
Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)).
Follow these steps to check the default paper settings.
Click the Windows icon
Click Hardware and Sounds
Click Printers
Right-click the icon for the product, and then click Properties
Click Printing Preferences
Click the Features tab.
Compare the settings in the Size drop-down menu with the paper in the tray. If the paper in the tray is not the size in the Size drop-down menu, change the setting:
a. Click the Size drop-down list, and select more. The Size is window opens.
b. Select the size of the paper that is in the tray, and then click ok.
c. Click OK in the Printing Preferences window, and then click OK in the Properties window.
Jul 21, 2010 | HP LaserJet 1020 Printer
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Dell 5100cn won't recognize mpf tray
Go to the printer web page by entering the IP address of the printer in an Internet Browser.
click Printer Settings menu entry
If the Substitute Tray value is not MPF Feed, click on the Printer Settings tab
Set the Substitute Tray value to MPF Feed
Click the button Apply New Settings, it will request the admin id & password for the printer.
In trying to resolve this issue, initially I set the Tray Settings to Panel Specified from Driver Specified at the printer's panel. Since the issue was resolved with this set, I just left it that way.
Nov 01, 2008 | Dell 5100cn Laser Printer
Ricoh Aficio 450 paper format printing problem
This could be a few things, first thing i would try is to go in page setup under the program you are using and make sure paper is set to auto select (File>page setup). The program will override the print driver.
next make sure the driver setting (paper source) are also set to auto. make these changes by right clicking on the driver>printing preferences.
third I would go to the copier, Make sure the tray are set to the proper paper size and the display paper size matches the tray
Dec 26, 2007 | Ricoh Aficio 450 Copier
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Brother MFC-8460N ... No Paper response
I had the same problem with a customer, to resolve this issue:
> Go to the printers folder
> Right click on the printer
> Go to printing preferences
> Under the paper source settings change it from autoselect to Tray1 and save the settings.
This will force the printer to print to tray1.
That fixed it for me, hope it works for you too.
Sergio Mayorga
Technical Support Representative
SACA Technologies, Inc.
Jun 16, 2007 | Brother MFC-8460N Laser Printer
Dell 5100cn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
