Question about Memorex MB2190
Must speak abnormally loudly to activate VAS system
Recorder will not activate automatically unless speaking very loudly and/or close to recorder. Seemed to work well on first couple of uses then began exhibiting above problems. Thanks bcpix
0 characters
1 Points
Loss of words during reording
I suggest that you allow little more silent time before pressing the pause or stop. also when you start regording again let it go for a second or two and then start talking.
you may also tap the mic pefore starting speaking, performers always tap the mic pefore starting to make sure its working.
Jun 18, 2008 | Philips SpeechMike Pro Plus 5276 Handheld...
I have a recorder and i want to converted to word do i need a software
you can move the recorded files into an MS WORD document BUT you can not automatically transcribe what is recorded onto a word document with any type of software, You can always use voice3 dictation to speak the information over and that would be the fastest but most costly options.
Jan 27, 2011 | Sony ICDP620 Digital Voice Recorder
Voice recognition using Sony ICD-P320 and Naturally Speaking
I would run compatibility check. It sounds like not compatible with Vista.
May 16, 2010 | Sony ICDP620 Digital Voice Recorder
Recently I purchased the Dragon Naturally Speaking 10. It works very well on straight dictation. However, I cannot seem to load my recordings from the Olympus VN-3100 PC unto the Dragon Speaking. Any...
There are several "flavours" of DNS 10, and only the Preferred and Professional versions will allow you to submit a pre-recorded sound for recognition (from the Sound menu). If you have a lower version such as the Standard, you will need to upgrade to at least Preferred.
I hope this helps
Jun 26, 2009 | Olympus VN-3100PC Digital Voice Recorder
English Operating Instructions
Hi slvio - Below is a link so you can download the English manual. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you Thanks.
May 15, 2008 | Olympus VN-3100PC Digital Voice Recorder
Instructions for speaking into a hand held dictaphone
Make sure that 'VOX' or 'VA' isn't turned on. This is Voice Activated recording and is designed to record only when the person is talking. The problem is that sometimes it'll cut in or out when you don't want it to.
Also, if the handheld has a 'Dict/Conf' switch, put it into 'Dict'. The 'Conf' setting is for conference recording - which will make the mic more sensitive and pick up more background noise.
Feb 13, 2008 | Dictaphone 1243 Handheld Cassette Voice...
Recording format
You'll need a software program to convert between audio formats. Here's a link to a free one that you can try:
If it isn't quite what you were looking for there are lots of free converters out there. Just go to and search for 'convert wma to wav' and you'll be presented with some choices, most of them free.
Jan 02, 2008 | Olympus WS-100 Digital Voice Recorder
Wow, I hit something that brought up folder 2 (didn't even know I had recorded in that folder). Stupid StoresOnline guy (STAY AWAY FROM THEM!) was speaking. on the side there is a stop/del button.
Try that, if you're still alive.
Nov 24, 2007 | Philips LFH-7630 Digital Voice Recorder
Voice Recorders Logo
14 people viewed this question
Top Memorex Voice Recorders Experts
David Burkhart
David Burkhart
Are you a Memorex Voice Recorder Expert? Answer questions, earn points and help others
