When I try to send a fax from my Olivetti Fax Lab 100 I keep getting 'TX ERROR'. What is causing this?
  • Anonymous Jan 20, 2009
    fax jx200 not sending or receiving faxes it shows NG error Tx report
    Genius:
  • 2,120 Answers
No dial tone detected.
Posted on Dec 04, 2008
I live in Spain and need a user manual in English please help olivetti lab 650
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/OLIVETTI/FAX-LAB-650-_E
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 16, 2011 | Cell Phones
My Canon MFP4150 cannot send international faxes. I keep getting error message 0091 : error during tx. Please advise a solution.
make sure the the phone line which you using having ISD calling facility in dialing 1 st you try that no by dialing with the normal phone.
Jan 20, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
"TX function was not completed" on my MP730
Probably some interference on your phone line...try a line filter.
Mar 26, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
When sending faxes, error pages always follows fax
go into menu -initial setup- look for the option that says tx report or com journal and set that to incomplete only or off, sounds like it is set to always. if the setting is not in the menu i mentioned keep scrolling through youll find it
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
FaxJet 335, tx error
call the number manually . and does it answer with a warble immediately or does the phone ring a lot and then answer.
your timeout may be set too short on the sending fax setup.
Dec 14, 2007 | Philips FaxJet 375 Plain Paper Inkjet
291 people viewed this question
jasbo
jasbo
