Question about Autotek MX1500.1 Car Audio Amplifier
Autotek mean machine 200xi
When i was hooking it up i didnt realize the key was on acc and the screw driver touched the amp case while i was tightining the speaker terminal (pos +) and sparked, now amp doesnt come on? what went wrong and where to look?it doesnt appear to be burnt anywhere. thanks
    New Friend:
Amp power turn on ic is fryed.. take it in to a shop.don't believe your friend that say's i can fix it for you.this is not something you can fix with some $5 sodering iron.price range will be between $35-$80 depending on shop.
Posted on Jun 20, 2013
Fuse blown maybe? check the fuse(s) on the amp, and also on your car's dash for audio or acc maybe. And check the bubble on your battery.
Posted on Feb 13, 2008
Amp light is green getting a base like heart beat nothing else fuses are good
The only thing I'm wondering is if you shorted out the RCAs somehow. Try switching the RCA's to another output on the back of the deck, if you have more than one set.
If that's not it...you will have to add pieces of the system one by one, starting at the deck, to see if you can troubleshoot the problem. Very Odd.
Good Luck
Dec 07, 2013 | Autotek Car Audio & Video
Installing a subwoofer in a honda integra
if you already have a after market radio hook the remote to either the remote/power antenna wire or the acc/key switch wire hook up rca,s run them down same side of car hook amp power wire down other side of care it stops engine noise make sure you do a good ground iy needs to touch bare metal for best performance hope this helps
Mar 03, 2013 | Kenwood Car Audio & Video
The words "autotek" and "STREET MACHINE" don't
IF the amp is working properly and just not lighting up...then it's just a matter of replacing the blown L.E.D.s that are needed to light the logo on the amp. You will need to remove the top cover to take out and replace the blown L.E.D.s
Please rate if this helped :)
Mar 17, 2011 | Autotek Machine SM1-1000 Car Amp
I have a clarion cz100 hooked up to a 1000 watt autotek amp and it is connected to a red top optimum battery. When i turn it up to BUMP it if im not moving the stereo will shut off. I had it hooked up to a...
some stereos will shut off if the voltage drops below 12 volts. measure your voltage at the battery with the car at idle and stereo turned up and all accesories and lights on. you should have 14.4 volts with the car running. the batteries voltage is 12.6 volts so you have to have more than this to be able to maintain steady voltage to your components. if the voltage drops too low when the bass hits it can shut off your radio. a capacitor can help this and the safe number is 1 farad for every 1000 watts. if you plan on adding any other amps autotek and phonix gold both make a digital capacitor that is compact and go anywhere from .5 farad to 10. the bigger the cap the better. if your voltage readings are ok then check that your speaker output wires are not touching.
Dec 23, 2010 | Clarion CZ100 Car CD MP3 Player
I HAVE 2 AUTOTEK MEAN MACHINES MODEL 66 AND THEY GO INTO PERTECT
Contact Eric @ Capital Audio & Electronics repair in Tallahassee FL we trepair all brands & models 850-339-1130
Mar 06, 2010 | Autotek Car Audio & Video
Autotek mm4000.1 locked it protect
try disconnecting the power and ground wait 30 mins then hook back up
Apr 12, 2009 | Car Audio & Video
Bobbin casing not in sync with needle.
When you have that hook drive gear back out turn the wheel until the needlebar is in its highest position. The bar with the teeth that the gear fits onto should be all the way to the right. Now slide the hook driver gear back on. You can lay the hook back in and slowly turn the wheel. Watch that the point of the hook on its upwards stroke is coming slightly above the eye of the needle. When it does this you will be in the correct position to put the screw back on.
Hope this helps. It may take a couple of tries but you will figure it out.
Oct 28, 2008 | Bernina Virtuosa 160
Aplifier gettieng protection signal and excess heat
for that amplifier, it is recommended that you are driving a 4 ohm load. It can drive a 2 ohm load, but will produce more heat and shorten the life of the amplifier. Is the subwoofer a single or dual voice coil? You'll want to make sure that you're not running below a 2 ohm load or you'll always go into protection. Also, try disconnecting the speaker wire completely from the amp so nothing but power is connected. If the amplifier is still in protection mode when no speakers are hooked up, then the amp is bad and will need repair or replacement.
Sep 28, 2008 | Autotek Car Audio & Video
Autotek amp
You got riped off if i were you i would go and get my money back because an amp like that cost around 399 to 499 dolars
Jan 24, 2008 | Autotek MX800.4 Car Audio Amplifier
Autotek mx1500.1
i am a master audio amp repairman i am working on an mean machine mx 1500.1 the RCA inputs wer just worn out on mine,
but your problem is much worse your power supply is gone, all mean machine`s are CLASS X mind you NOT CLASS D basicly all that means is that the audio feads directly into one big power supply unit instead of having both an input and output stage.I recomend you find a web site or audio shop with a phone number
for the autotek corp. and have it sent in..DO NOT WORK YOURSELF
Jan 30, 2007 | Autotek MX1500.1 Car Audio Amplifier
Autotek MX1500.1 Car Audio Amplifier Logo
162 people viewed this question
Top Autotek Car Audio & Video Experts
kli99gunrunn
Tom Chichester
FastHarley
FastHarley
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
