Question about Autotek MX1500.1 Car Audio Amplifier
Autotek mx1500.1 i have an autotek mx1500.1 and it doesnt power on. when i first hook up the power and ground it will spark at the connection(the battery)but then does nothing, no power light on or anything. any suggestions?
I am a master audio amp repairman i am working on an mean machine mx 1500.1 the RCA inputs wer just worn out on mine,
but your problem is much worse your power supply is gone, all mean machine`s are CLASS X mind you NOT CLASS D basicly all that means is that the audio feads directly into one big power supply unit instead of having both an input and output stage.I recomend you find a web site or audio shop with a phone number
for the autotek corp. and have it sent in..DO NOT WORK YOURSELF
Posted on Feb 21, 2008
Why does the ground cable spark when u hook it up to the battery?
ground cable doesnot connect to the starter!! positive,+.goes to the red side,neg - is ground
Jun 25, 2015 | Cars & Trucks
When battery ground is hooked to moter the fuel pump doesnt receive power
That's skimpy info to go on.. What else does not work? The ground or negative wire (usually) should be connected to the car body and the motor both. You cannot count on the ground connection from motor to body. If all else is working suspect the fuel pump, but your question seems to indicate it works if gound is to body(?)
Mar 08, 2012 | Ford Festiva Cars & Trucks
Wont turn on. everything should be connected properly, got new fuses to make sure. It worked fine until i dismounted and disconnected it from the battery. When i reconnected it, no luck it is a Autotek...
Make sure this high powered amp is not mounted directly to the chassis of the car. Mount it to a wooden board and you can screw board into the car. Because some very high powered amps can arc and damage itself.
Next make sure the tubular fuse in the hood is not bad it may look good but internally it got real hot and caused a bad solder connect in the fuse. You can test it with a meter. Measure one side then the other side if the 12 volt is going thru the fuse.
Next step is now you know your amp is getting 12 volts from the car battery but do you know if your amp turn on signal is turning on the amp itself. This is a easy test get a little wire and jump the 12 volt to the amp turn on wire if the amp comes on then you have found your problem. The amp turn on voltage is too weak were ever youve connected the signal. Normally you hook it up to the blue/white wire on the back of the radio first. If it doesnt have one hook up to the blue. Now on some very rare occassions the voltage drops when you put a load to it and is not enough to turn on your amp you can easily see this if the voltage across the blue wire goes below 12volts so hook it up to the red ignition wire so at least when you turn on your radio the red will send 12 volts to the amp to turn it on and will not drop in voltage. You see that wire has to be 12volts when it drops the amp will not turn on. Same with the battery Voltage you have to maintain 12 Volts or higher for the amp to operate.
Apr 08, 2010 | Autotek Super Sport SS-400.4 Car Audio...
I bought a hifonics bxi2006d new and doesnt turn on
you should not have any spark from your ground...you may want check and make sure your ground is properly installed. Try wiring the amp without the cap and see if that works.
Mar 28, 2010 | Hifonics Brutus BXi 1206D Car Audio...
STEREO SHUTS OFF BY IT SELF. IT IS AUTOTEK MM1400.1D what size fuse shoud be in it?it has two 40s in it now.
sounds like the protection circut of amp. check for solid ground and continous power from battery. Doed it get very hot?
Sep 17, 2009 | Autotek Car Audio & Video
Autotek mm4000.1 locked it protect
try disconnecting the power and ground wait 30 mins then hook back up
Apr 12, 2009 | Car Audio & Video
Amplifer
recheck your ground make sure it has a good connection most of the time this is what it is
Feb 11, 2008 | Autotek SS290.2 Car Audio Amplifier
Help me
If the wire is getting hot, the fuse in it is too large and you're in danger of burning your car to the ground.
Generally, if the amp draws excessive current only AFTER remote is applied, the output transistors have failed. If solder has melted, it may have bridged other traces and could cause more extensive damage.
Oct 28, 2007 | Autotek XS-900.2 Car Audio Amplifier
Autotek mean machine 200xi
fuse blown maybe? check the fuse(s) on the amp, and also on your car's dash for audio or acc maybe. And check the bubble on your battery.
Jan 30, 2007 | Autotek MX1500.1 Car Audio Amplifier
Autotek MX1500.1 Car Audio Amplifier Logo
264 people viewed this question
Top Autotek Car Audio & Video Experts
xxxxxx xxx
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
