Question about Philips Magnavox 42MF521D/37 Television
Hooking my flat screen tv to my home theater
The only audio out connection is (SPDIF) on my theater i have rca audio in
  • 558 Answers
Since your output is coaxial (rca) you should be able to find an input for coaxial that will work on your surround the setting on your surround will be either coaxial or digital input,
hope this helps
it would help if you said what kind and model of surround you have
Posted on Dec 09, 2008
How do I connect my flat screen tv to my Phillips MX3900 system
This is an older home theater package and only has component video out for HD and RCA or SPDIF optical out for audio. You'll need to locate the component video input on the back of your flat panel and connect it to the component output of the Phillips unit. Component cables have 3 RCA cable (Red, Blue, Green) for HD. You can use a RED/WHITE RCA cable for audio but if you have a SPDIF Optical cable you should use that for better sound. The TV should have that as an input also. You will need to go into the Menu for the TV and select component video and SPDIF optical if you went that route for audio.
Dec 03, 2014 | Philips MX3900 System
Do i need to buy anything extra for my ilive 37' soundbar for my tv? The sound doesnt work with my tv, but the bluetooth works just fine.
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
Nov 28, 2014 | iLive 2.1 Channel Sound Bar ITP152B
I Just recently bought this have it hooked up to my Computer through a Digital audio Coaxial cord . The problem is this 600 - Watt system is emitting less power than the 300 watt one it replaced that was...
Audio power is relevant only between the amp and the speakers. Check the volume setting of the source and any audio settings in the PC.
SPDIF is not Red and White. If anything it is a single coaxial RCA connector.
Wattage specs for comparison are pure fiction at this level. 10% distortion fudges the number upward.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
Defeat any bass enhancement in the source until you figure out the level issue.
Mar 23, 2011 | RCA RT2910 Theater System
RCA RTD325W via HDMI cable to VIZIO E320VP - How do I get sound from TV to play out of Home Theater unit? More cables required? Buttons to push? Thank You. F.Frost
The TV has a SPDIF ( coaxial ) digital out socket at the back . Get yourself a digital cable and connect it to the RCA Home theater systems coax digital inputbobhifi_16.jpg
Mar 16, 2011 | RCA Audio Players & Recorders
How do you hook up a home theater system without an out put
Hi, on this TV there is a SPDIF port that they say to hook-up to your home theater system. Depending on your amp receiver if it has an spdif port then thats the way to go. if not then you could always run audio cables from your cable/satellite box to your amp receiver, and the same for your dvd player and any other device. Hope i was of some help : )
Feb 12, 2011 | Apex Digital LD4088 LCD TV
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
I have a 37 WLT 68 TV, is it possible to connect
Strictly speaking, no. Your TV has both a line-level audio output, via RCA cables, and a SPDIF (digital audio output) connector (and a headphone jack). Any of these will output a low-level signal into an stereo amplifier or home theater AV receiver. The speakers would be attached to that separate amplifier unit.
Oct 16, 2009 | Televison & Video
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Feb 27, 2009 | Coby 5.1 Channel Home Theater Speaker...
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
Philips Magnavox 42MF521D/37 Television Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
