Question about Intel Motherboard
Mainboard problem Hi, I had a problem similar to yours with a VL-601 motherboard. I dusted the PC inside, pulled the three RAM modules off and then secured them back in place again, and rebooting the system I got the sequence of slow, long "beeps", and no video output. Any suggestions? Thanks in advance for cooperation. Massimo from Italy
  • massimo344 Dec 03, 2008
    Yesterday night I checked all the connections and finally tried to pull out the RAM modules again, all the three of them. Then I reinstalled them one at a time, discovering that the problem was there: after installing the first module, the PC booted properly. The same with two modules. In the third module sat the problem. Perhaps I damaged it while dusting the PC. Hope this helps.
    Massimo
  • 144 Answers
Clean the dust from the RAM socket completely by blowing air with a antistatic blower. Clean the RAM contacts with the pencil eraser & then fit into the socket.
If still no luck, try with a single stick to find out the faulty one..
Posted on Dec 04, 2008
Boot problems
SOURCE:No boot No video on new built pc with a msi motherboard a55m-p33 amd, three beeps at start up.
Hello here is the homepage:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Driver&os=Win8%2064
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Tree beeps means you have a ram module failure, or not inserted correctly.
This mainboard uses DDR3 ram, up to 16 gb.
Try to start with only one module at the time.
Try also to check the manual:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
Jan 14, 2014 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
Ei systems 4411 wont power on mains or battery
Try pulling out and putting back in place the ram modules, the motherboard can be faulty.
Oct 30, 2008 | Computers & Internet
ASUS XP PROFESSIONAL MODEL K8V-VM
Hello try to insert the old ram module again.
Your mainboard uses DDR ram, not DDR2 or DDR3 these to will not fit the socket.
The mainboard only supports up to 2 gb of ram.
If more ram is insertet, the mainboard will not boot.
More info can be found here at ASUS:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=20&m=K8V-VM&os=17&hashedid=IQoVElAYUAC4aAz3
Try to download the manual, by selecting your windows system.
You will need adobe reader, to read the content.
The manual should also be helpfull when connecting the cables in the right order again.
Remove also any dust inside the pc, with compressed air.
And take antistatic precautions when working on the mainboard !!
Hope you will get the pc running again :-)
Jun 20, 2013 | Computers & Internet
My GA-VM900M Mother board gives a long beep after another when I switch it on. The monitor remains black and the power light stays on.
http://www.gigabyte.com/products/product-page.aspx?pid=2581#dl
Drivers or the manual can be selected in download type.
A long beeb is a fault in a RAM module.
Try to insert a ram module you know is working.
Your mainboard use DDR 2 ram, up to 4 GB.
Another fault could be the power supply.
Blow also any dust out with compressed air before working on the mainboard and take antistatic precautions
Here is a list of beeb codes:
Good luck
Jan 04, 2013 | Computers & Internet
Tried to upgrade memory on Asrock K8NF4G-SATA2 to 2 X 1Gb modules. With one module fitted PC starts and shows 1Gb. With 2 fitted it will not start. Tried both modules one at a time in slot 0 and board will...
http://www.asrock.com/mb/NVIDIA/K8NF4G-SATA2/
I think the second slot for the ram might have a defect.
The problem could also be a bios setting or an update.
The bios can be upgraded while the system is running.
If you are in doubt upgrading the bios let a expert do this for you.
Remember that dust can make a bad connection and do not touch the contact points with your fingers.
Try to buy a can with compressed air and blow the ram slot out for dust.
The ram modules must sometimes be at equal size (mhz) in order to the mainboard can boot with the ram.
Good luck
Dec 16, 2012 | Asrock K8NF4G-SATA2 Motherboard
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
8 gig of ram installed but win 8 pro 64 bit only see 4 gig, Win 7 Home Ultimate 64 bit had same result
Hello the homepage is here:
http://www.supermicro.com/products/motherboard/PD/955/PDSG4.cfm
Check for one of the modules is in place in the ram socket
and blow it out for dust with compressed air.
One of the modules could also have a defect.
The mainboard supports:
Up to 8GB dual channel unbuffered
ECC/non-ECC DDR2 667/533/400 MHz
Try also to upgrade the mainboard drivers with this tool:
http://www.intel.com/p/en_US/support/detect?iid=dc_iduu
Good luck
Oct 29, 2012 | SuperMicro PDSG4 Motherboard
1 bib long???????????????
This usually indicates that the mainboard is not able to detect the RAM in the RAM slots. In other words it is saying that there is no RAM installed in the mainboard.
What you can do is clean the RAM slots of dust with a vacuum cleaner and clean the gold finger contacts of the RAM modules with tissue paper.
Push the RAM modules in firmly in the the correct orientation. Notice the cut-out on the RAM modules, between the gold fingered connectors.
It might be possible that the RAM modules that you have currently installed in the system are faulty, in other words they have died. This could be a bit tricky and you may need a computer technician to try some known to be working RAM in your mainboard.
Clean out as much dust as you can from the system, it will help.
Take care!
damnor01
Jul 04, 2011 | ASUS A7S8X-MX Motherboard
Pc doesn't start properly, and displays a 1 & 3 on the front panel
Memory modules are detected, but a memory configuration or compatibility error exists.
May 11, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
Intel Motherboard Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
