Question about Samsung SyncMaster 753S 17" CRT Monitor
No signal from cpu
My monitor comes on once plug in but as soon as cpu connect to it then it turn off.when unscrew from cpu the signal comes on but once connect to cpu , no signal.other monitor works so its not the cpu
  • arkpraveen Feb 16, 2008
    I am also having the same problem.Whenever i switch my cpu on,the monitor goes dead.if i remove the cpu connection.it shows the "no signal" message.can anyone help me out.
  • 3 Answers
I think you should check if the sync wires are properly connected both on the db15 connector and the main board
Posted on Jan 08, 2008
No signal to monitor
Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
May 05, 2011 | Acer Aspire M1641-U1521A PC Desktop
I plug in all of the wires correctly. I just bought a brand new acer monitor and connected to the CPU and when I try to turn on the CPU and monitor I get a message on the screen saying "no signal" What...
You will need to download and install the very latest drivers for the printer. You can probably find the latest drivers on the manufacture's site or others. Then after that you will want to turn on printer then connect usb after it is turned on>
Oct 10, 2009 | Acer Office Equipment & Supplies
I just bought a Acer 19' monitor and I'll trying to connect it to my Dell PC. It came with to cables (blue and white). The blue goesinto the back of the PC Tower but the white one fits nowhere. When the...
they all come with two cables. blue being vga, white being dvi cable. you only need to plug the blue into both ends (computer and into the monitor) and turn on. If it is still not working how many video cards are there on the computer? Do you have it plugged into the right spot and is it tight on both ends?
Jul 23, 2009 | Acer AL1916W 19" LCD Monitor
No signal when power button turn on
Sounds like either the power supply unit's fan isnt functioning and the the uniy over heats and the computer then wouldnt boot up (to protect itself) or the processor is overheating. But rather seems like a power supply problem
Jul 06, 2009 | Acer AL1916W 19" LCD Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
I have a pavillon a6421 uk hp computer when i turn it on the monitor comes up with no vga signal (i have changed the graphics card and it is still the same) have done all the trouble shooting options...
Hi
First Check the power cable of ur monitor whether power is coming or not..
Then remove signal cable (which is connect the cpu) and then switch one the power, check whether any msg is coming in screen.(like no signal or no connection) if it comes means u want to check the cpu or else their is problem in ur monitor..
Connect the another monitor with ur cpu.Whether ur cpu is working properly..
Sep 19, 2008 | Computers & Internet
Alienware computer
Please try connecting monitor to known working CPU and determine if problem is with CPU (Graphics card etc) or monitor.Signal cable can also be a problem.
Please rate solution and provide feedback.
Samir
Jun 09, 2008 | BenQ FP71E 17" LCD Monitor
Monitor
Maybe it's because it's not getting a signal from the CPU.
Make sure that CPU is working on another monitor.
Thanks,
Lolita
Apr 08, 2008 | Computers & Internet
I turned my computer off to move to another location, unplugged my aopen monitor... when I replugged everything back.. my monitor would not come on... the power button is flashing.. but ...
Take a look behind the computer. If there is more than one monitor port, try plugging the monitor into the other one. Also, certain monitor cards are notorious for not staying in the slot if you move the plug from the monitor around, or even unscrew it. My best bet is that if you open the case (turn off and pull the power plug first, then touch the frame to release static, you'll see that the back of the card is pulled up a little, exposing the connectors on the bottom. Pull the card all of the way out and reseat it into the slot. If the card was not connected before it should be now. Good luck.
Mar 25, 2008 | Computers & Internet
Samsung SyncMaster 753S 17" CRT Monitor Logo
103 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
